Zinc oil additive #60882
05/21/08 11:13 AM
05/21/08 11:13 AM
Anonymous OP
Anonymous OP
Anybody know of a zinc oil additive for a flat tappet cam. I would hate to drain all of the Quaker State Synthetic Oil I just put in.
Re: Zinc oil additive #60883
05/21/08 11:28 AM
05/21/08 11:28 AM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I just used an additive from Lucas to break mine in. There are several on the market, Jegs has several listed on there site.
Re: Zinc oil additive [Re: stroked470] #60884
05/21/08 11:37 AM
05/21/08 11:37 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
All the cam manufacturers sell it too.
Re: Zinc oil additive #60885
05/21/08 06:43 PM
05/21/08 06:43 PM
Richmond , Virginia
chagjr Offline
chagjr  Offline
Richmond , Virginia
ZDDPLUS
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: Zinc oil additive [Re: chagjr] #60886
05/24/08 03:39 PM
05/24/08 03:39 PM
Anonymous OP
Anonymous OP
I use the comp cams stuff. They have it at my local Napa store.
Re: Zinc oil additive #60887
06/25/08 08:39 PM
06/25/08 08:39 PM
Anonymous OP
Anonymous OP
Gm EOS is back out. New part number is: 88862586
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=1052367
Re: Zinc oil additive #60888
06/25/08 08:42 PM
06/25/08 08:42 PM
Kirkland, Washington
Pacnorthcuda Offline
Gm EOS is back out.
So anyone know if the chevy/pontiac etc parts departments are likely to have it on the shelf?
Re: Zinc oil additive [Re: Pacnorthcuda] #60889
06/25/08 08:44 PM
06/25/08 08:44 PM
Anonymous OP
Anonymous OP
Probably but you'll pay a lot more, $12.17 on my link, $19.99 at Jegs so.............
Re: Zinc oil additive #60890
06/25/08 11:40 PM
06/25/08 11:40 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
I just paid $21 for EOS, never again will I buy it
Re: Zinc oil additive [Re: rck850] #60891
06/26/08 12:43 AM
06/26/08 12:43 AM
Anonymous OP
Anonymous OP
Because of the price? Care to elaborate?
Re: Zinc oil additive #60892
06/26/08 05:47 AM
06/26/08 05:47 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
i got 6 bottles of EOS from those guys a couple of months ago. Reasonable shipping.
Re: Zinc oil additive #60893
06/26/08 06:01 AM
06/26/08 06:01 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I'd just like to point out that GM E.O.S is an engine assembly lube and not a motor oil additive as stated by GM.
Re: Zinc oil additive [Re: CompSyn] #60894
06/26/08 06:53 AM
06/26/08 06:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
did they change the formulation? because the bottles I had (old part number that they quit making a few years ago) said that you can use it as engine assembly lube, and as an oil additive for engine break in.
if it's ok to put in the oil on engine break in, why can't you put it in the oil at every oil change to save your cam from zinc-less modern oils?
**Photobucket sucks**
Re: Zinc oil additive [Re: 70Cuda383] #60895
06/26/08 07:18 AM
06/26/08 07:18 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I think they've "rebranded" it - it can perform the same functions as before (break-in and/or oil additive) but they can't promote it as an additive any more for the same reasons they've taken ZDDP out of oil, namely damaging catalysts.
That's not to say whether they did or didn't change the formulation at all, I don't know about that, but I do think that's the reason for not marketing it as an additive.
Re: Zinc oil additive [Re: 70Cuda383] #60896
06/26/08 07:44 AM
06/26/08 07:44 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Looks like GM has changed the recommendation on the E.O.S. I'm to understand it is currently marketed as engine assembly lube only. But I don't actually have a bottle in of it in hand to see what the current recommendation is.
For other thoughts on this, check out:
http://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/473053/site_id/1
Re: Zinc oil additive [Re: CompSyn] #60897
06/26/08 07:47 AM
06/26/08 07:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
This could actually be a good thing...
same old formulation that we want, with tons of zinc, but if they change the "application" to assembly lube only and NOT oil additive, then they don't need to take the zinc out to meet current EPA requirements on modern cat equiped vehicles.
Re: Zinc oil additive [Re: 70Cuda383] #60898
06/26/08 08:34 AM
06/26/08 08:34 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Yes, it may be a good thing?
I’d just be a little cautious when going against manufacturers recommendations. If you decide to chance it, you’re on your own.
And, there’s always the old hot rodders adage, “If a little is good, then more is better.” Or is it? If you’re using a motor oil with a good known level of protection additives already blended in, then why worry about additives?
I reason that burnishing a new cam a lifters together for the first time is one application, normal engine operation is another. That said, I’d use the Engine Oil Supplement for the intended break-in use, drain, then add a motor oil with good ZDDP levels, and sleep soundly at night.
Re: Zinc oil additive [Re: CompSyn] #60899
06/26/08 03:09 PM
06/26/08 03:09 PM
Illinois
SteveA Offline
SteveA  Offline
Illinois
[quote then add a motor oil with good ZDDP levels, and sleep soundly at night.
Any recommendations ?
Steve
Re: Zinc oil additive [Re: SteveA] #60900
06/26/08 03:29 PM
06/26/08 03:29 PM
scratchnfotraction Offline
stp oil tretment and the red bottle stp
and the stp oil stablizer in a quart bottle with a pic of king richard on it...the racers edge!
I gots about 2 doz quart bottles at a big lots 2$ a bottle...think it is not made any more though
I run the napa fleet oil in a 15-40 thats still up there in the zddp
Re: Zinc oil additive [Re: SteveA] #60901
06/26/08 05:08 PM
06/26/08 05:08 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Sure! The motor oils in the link are my recommendation:
http://www.competitionsynthetics.com/about/about.htm
