Heat cracks in flywheel.? #608783
02/09/10 01:25 PM
02/09/10 01:25 PM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
I had my 130 tooth flywheel resurfaced{ground} and some small heat cracks still remain..Manchine shop says no problem ???
Re: Heat cracks in flywheel.? [Re: RTshaker] #608784
02/09/10 01:38 PM
02/09/10 01:38 PM
Canada
RobR Offline
RobR  Offline
Canada
Not a problem...
Re: Heat cracks in flywheel.? [Re: RobR] #608785
02/09/10 02:49 PM
02/09/10 02:49 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Not a problem...
Not a big deal
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Heat cracks in flywheel.? [Re: 68LAR] #608786
02/09/10 03:13 PM
02/09/10 03:13 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
not a huge deal but I can tell you that I have flywheels turned on a regular basis here at work and my machine shop has never left any cracks
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Heat cracks in flywheel.? [Re: 68LAR] #608787
02/09/10 03:43 PM
02/09/10 03:43 PM
RTshaker Offline OP
RTshaker  Offline OP
Thanks.. I was wondering, as every search on google seemed to say NOT to trust it . When I looked at selling it was treated as a leper??
Post deleted by Defbob [Re: dusturbd340W5] #608788
02/09/10 04:51 PM
02/09/10 04:51 PM
Re: Heat cracks in flywheel.? #608789
02/09/10 07:57 PM
02/09/10 07:57 PM
Kissimmee Fl.
Kissimmee Fl.
some flywheels can only be cut so much
that's correct I guess what I was saying is I have never had a flywheel they couldn't get the cracks out of they also make crank shims to keep the flywheel in the original location.
