AMD has full 1/4's and tail panel for the car.
I have a trunk pan, rear frame rails/cap and some other small parts.
Look at the roof panel, probably tweaked somewhere. If that's the case, the floor pan might be toast as well.
Sorry to read that. Same thing happened to a 65 Mustang GT I owned in the 80's. Drunk hit it and moved it about 100 feet down the street into another car.
Good luck with it and don't let the adjuster beat you down on the value of your car. Get a bunch of comparable values from hemmings, web, etc.
