318 Rear Main Seal #608296
02/08/10 10:05 PM
02/08/10 10:05 PM
Kentucky
dfsmopars Offline OP
Kentucky
I pulled the flex plate cover and did a good inspection tonight on my 318 and confirmed I am doing a rear main seal this weekend, if time allows. Looks like the oil pan will come off easy enough with the drag link out of the way. Does anyone care to offer any words of experience and are any seals better than others?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 318 Rear Main Seal [Re: dfsmopars] #608297
02/09/10 07:48 PM
02/09/10 07:48 PM
Spring Grove, PA, US
Mr.Mopar Offline
Mr.Mopar  Offline
Ive put 4 rear main seals in..
Make sure it is installed in the correct direction I unfortunatly learned that the hard way on my duster..
I like to put a small dab of silicone where the 2 halfs meet. also make sure the silicone isnt too old and wont dry. also learned that the hard way.
all mine have fel-pro gaskets and none of them leak. now..
good luck
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: 318 Rear Main Seal [Re: dfsmopars] #608298
02/09/10 11:23 PM
02/09/10 11:23 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you sure it's not a tranny front pump seal?
2017 Grand Cherokee Overland
Re: 318 Rear Main Seal [Re: patrick] #608299
02/10/10 05:52 AM
02/10/10 05:52 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
You'd have to be pretty dense to confuse a tranny leak with an engine oil leak...
Re: 318 Rear Main Seal [Re: patrick] #608300
02/10/10 07:04 AM
02/10/10 07:04 AM
Kentucky
Kentucky
Yea I can see the oil pretty heavy between the oil pan and bell housing. It only leaks after I have run it and then shut it off. I also verified it is not coming from the back of the intake.
Re: 318 Rear Main Seal [Re: dfsmopars] #608301
02/10/10 09:29 AM
02/10/10 09:29 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
guess I haven't seen to many rear main leaks...it's usually back of the intake or the oil pressure sending unit that I've seen, and if it's coming from inside the bell of the tranny, it's been the front pump seal of the tranny, or maybe the oil pan
