340 block id'ing help #606634
02/07/10 01:40 AM
02/07/10 01:40 AM
mopar country
O
omnicrazy Offline OP
O
mopar country
I am trying to id two 340 blocks I have but am confused. Some of the stamping are very hard to read.
cast date 9-10-68
number in pass side of oil pan rail=
BH29P9R162347
number on drivers side below head=
FW340P26220125
Second block:
cast date 2-11-72
number on oil pan rail=
2P453085
Number below head=
HM340R39538015
Question 1) Why is there a difference in the number of digits by the oil pan?
Question 2) Is there a direct connection between the numbers by the head and oil pan?
I have been trying to figure it out in the little white numbers books but I am so confused.
Any help would be great
Re: 340 block id'ing help [Re: omnicrazy] #606635
02/07/10 01:50 AM
02/07/10 01:50 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
cast date 9-10-68
BH29P9R162347
FW340P26220125
F=1970 Series model year engine (I'm betting it's an E which =1969)
W = Windsor Plant
340 = Cubic inches
P = Premium Fuel
2622 = October 1, 1969 Assembly date
125 = Sequence assembled
Second block:
cast date 2-11-72
2P453085
Number below head=
HM340R39538015
H = 1972 series model year engine
M = Marysville Plant
340 = Cubic Inches
R = Regular Fuel
3953 = Assembly date = May 24, 1972 assembly date
8015 Assembly sequence
The difference in the VIN# on the oil pan rail is simple, in some 1969 vehicles (in this case a 69 Barracuda) the full VIN# is stamped there. In the later years they abreviated the VIN#.
Re: 340 block id'ing help [Re: ScottSmith_Harms] #606636
02/07/10 01:54 AM
02/07/10 01:54 AM
mopar country
O
O
mopar country
cast date 9-10-68
BH29P9R162347
FW340P26220125
W = Windsor Plant
340 = Cubic inches
P = Premium Fuel
Second block:
cast date 2-11-72
2P453085
Number below head=
HM340R39538015
340 = Cubic Inches
R = Regular Fuel
Now that I look at it is an E
Can you tell what car they came in?
Next stupid question why would one need premium fuel?
Re: 340 block id'ing help [Re: omnicrazy] #606637
02/07/10 01:56 AM
02/07/10 01:56 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Check my plant info on the second one, I made a correction.
In 1972 they dropped the compression ratio which allowed the use of Regular fuel, previous years had higher compression requiring premium.
Re: 340 block id'ing help [Re: ScottSmith_Harms] #606638
02/07/10 01:58 AM
02/07/10 01:58 AM
mopar country
O
O
mopar country
Thanks I am slooooowwwly figuring this stuff out
Re: 340 block id'ing help [Re: omnicrazy] #606639
02/07/10 01:58 AM
02/07/10 01:58 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The older engines had higher a higher compression so Premium fuel was reccomended.
Re: 340 block id'ing help [Re: ScottSmith_Harms] #606640
02/07/10 02:01 AM
02/07/10 02:01 AM
mopar country
O
O
mopar country
So there is really no way to know what car the 72 came in since it only had a partial vin right?
(unless you had the vin of the car)
Re: 340 block id'ing help [Re: omnicrazy] #606641
02/07/10 02:02 AM
02/07/10 02:02 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's correct
Re: 340 block id'ing help [Re: ScottSmith_Harms] #606642
02/07/10 02:03 AM
02/07/10 02:03 AM
mopar country
O
O
mopar country
Thanks again
Re: 340 block id'ing help [Re: ScottSmith_Harms] #606643
02/07/10 02:03 AM
02/07/10 02:03 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
BH29P9R162347
Could this be BH29P9B162347 ?
Also, for the engine serial numbers (not to be confused with the VIN) you can check the TSBs.
The TSBs that deal with the engine numbers are always in Chapter 25 & normally one of the first ones in the chapter;
http://www.hamtramck-historical.com/library.shtml
Re: 340 block id'ing help [Re: omnicrazy] #606644
02/07/10 02:09 AM
02/07/10 02:09 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It depends. In a lot of cases I can tell what they came from for 1970 Hamtramck VINs. (as you know already)
1972, not so much, but I do not collect data on them. If someone did though.....
That said, is this;
2P453085
2B 453085 or 2R 453085?
P is right out.
Re: 340 block id'ing help [Re: Alaskan_TA] #606645
02/07/10 02:20 AM
02/07/10 02:20 AM
mopar country
O
O
mopar country
could be a B instead of R
what would the difference be?
like I said the stampings are very hard to read
Re: 340 block id'ing help [Re: Alaskan_TA] #606646
02/07/10 02:21 AM
02/07/10 02:21 AM
mopar country
O
O
mopar country
That said, is this;
2P453085
P is right out.
I am confused about what you're asking or telling me
Re: 340 block id'ing help [Re: omnicrazy] #606647
02/07/10 02:25 AM
02/07/10 02:25 AM
mopar country
O
O
mopar country
but wouldn't itt make sense that the assmbly and casting place were windsor?
Re: 340 block id'ing help [Re: omnicrazy] #606648
02/07/10 02:26 AM
02/07/10 02:26 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Sorry.
P is not a valid plant code, so could the second digit be a B or an R?
Re: 340 block id'ing help [Re: Alaskan_TA] #606649
02/07/10 02:28 AM
02/07/10 02:28 AM
mopar country
O
O
mopar country
I think I am half blind most of the time I will have my wife look at the numbers tomorrow.
Re: 340 block id'ing help [Re: Alaskan_TA] #606650
02/07/10 02:29 AM
02/07/10 02:29 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Windsor had a car plant as well an an engine plant.
The Windsor engine plant made the 340s for Hamtramck.
Re: 340 block id'ing help [Re: Alaskan_TA] #606651
02/07/10 02:30 AM
02/07/10 02:30 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Clear, close up photos would help.
Re: 340 block id'ing help [Re: Alaskan_TA] #606652
02/07/10 02:30 AM
02/07/10 02:30 AM
mopar country
O
O
mopar country
Sorry.
P could mean export right?
I am not saying that is a P for sure but the data I got from the year one website says that the P is export. Like I said I am all confused but I am learnin
Re: 340 block id'ing help [Re: Alaskan_TA] #606653
02/07/10 02:31 AM
02/07/10 02:31 AM
mopar country
O
O
mopar country
I will try that tomorrow too
