Page 1 of 3 1 2 3
Best Street Gear Ratio?? -HELP #60630
05/20/08 10:31 PM
05/20/08 10:31 PM
Columbus, Ohio
A4SixtyNineRR Offline OP
Columbus, Ohio
Hey guys I want to get everyone's opinion on this one. I have a '69 RR that I am currently restoring and I am trying to decide what gear ratio to use in the rear end (currently a 3.23). I want to be able to use it on the street for cruising, but want to be able to light up the tires when I feel the need. The obvious choices are 3.55, 3.73, or 3.91 for the set up but I have only driven a 3.91 other than my 3.23. I am afraid a 3.91 might be too low and give me too high of rpm's with whining going down the highway. SO I am thinking that narrows it down to 3.55 or 3.73. Any opinions on which is better or is there even a noticeable difference between the two? Thanks for helping out!!
Re: Best Street Gear Ratio?? -HELP [Re: A4SixtyNineRR] #60631
05/20/08 10:34 PM
05/20/08 10:34 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Whats wrong with the 3:23? I had that in my cuda and
it would light the tires up just fine plus would top
it out at around 140 MPH.
I have a 2:76 in my dart thats a 4 speed that roasts the tires off. Sell me your 3:23 if you don't like it.
Re: Best Street Gear Ratio?? -HELP [Re: Dart 340] #60632
05/20/08 10:43 PM
05/20/08 10:43 PM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
3.55.
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: Best Street Gear Ratio?? -HELP [Re: A4SixtyNineRR] #60633
05/20/08 10:45 PM
05/20/08 10:45 PM
roadrunners where light to light terrors.. NOT hiway cruizers.. so stick some 4.30's in there.
Re: Best Street Gear Ratio?? -HELP [Re: A4SixtyNineRR] #60634
05/20/08 10:53 PM
05/20/08 10:53 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Again,
I'll take the 3:23's off your hands.
Re: Best Street Gear Ratio?? -HELP [Re: Dart 340] #60635
05/20/08 11:38 PM
05/20/08 11:38 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm gonna go against the grain here. I run 3.91's in my Satellite, and love them. But, My car is used around town only. It rarely sees freeway miles, and when it does, I'll admit its not exactly the hot ticket! If you do any freeway miles, I'd go with 3.73's, just so you can peek at 60 MPH below 3g. If its just a Saturday Night Special, and you're in it for the fun factor.....3.91's are fun. Heck... 4:10's!!!
Re: Best Street Gear Ratio?? -HELP [Re: CHRONiklyDEMONic] #60636
05/20/08 11:40 PM
05/20/08 11:40 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
3.55. The best gear choice ever. Period. My friend has a fox body mustang that run's 7.90 in the 1/4 mile, with a 3.55 gear.
why would anyone care what your friend has...
Re: Best Street Gear Ratio?? -HELP [Re: mcat4321] #60637
05/20/08 11:59 PM
05/20/08 11:59 PM
Puyallup, WA
Puyallup, WA
My friend has an Alcohol Funny Car!!!!
Re: Best Street Gear Ratio?? -HELP [Re: StealthWedge67] #60638
05/21/08 12:57 AM
05/21/08 12:57 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have a 2.76 in my 318 cuda and it will lite em up real good. It is great on the highway unless I plan to break a speed limit at all, then I wish I had even higher. I would use the 3.23 or higher for cruising and especially considering MPG these days.
Re: Best Street Gear Ratio?? -HELP [Re: HotRodDave] #60639
05/21/08 01:37 AM
05/21/08 01:37 AM
8-3/4 is a pretty quick swap, enough practice and you can change gears in 20 min. I have 3.91 in my runner and like it, but change to 2.76 for the highway. If I had 4.88 I would probably use that for bursts about town. I do like 3.55 as an all around gear.
Re: Best Street Gear Ratio?? -HELP #60640
05/21/08 09:19 AM
05/21/08 09:19 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Also depends on what size tires you have in the rear. I like my 3:55's with a 28" tire. With a 28" tire I also would not be afraid of cruising the highway with 3:73's either. I had 3:91's for a couple years and it was fun, but the highway was a bit much for trips over 1.5 hours. I'm not a sissy, but the rpm's and noise get annoying.
Re: Best Street Gear Ratio?? -HELP [Re: Jeff_383] #60641
05/21/08 09:24 AM
05/21/08 09:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
depends on how much highway driving you are going to do. What are the engine specs..and on and on. 3.91's are a good gear for a b-body. With a set of 275/60/15's you can cruise at 70 no problem. 3.55's are ok but they are dog gears compared to 3.91's...as are 3.23's. Try the 3.73's they are pretty new to mopars. Let us know how they run.
Re: Best Street Gear Ratio?? -HELP [Re: Mr.Yuck] #60642
05/21/08 09:29 AM
05/21/08 09:29 AM
i drove with 4.30's on the hiway with a 28" tall tire at 60-65mph.. wasn't all that bad.
Re: Best Street Gear Ratio?? -HELP #60643
05/21/08 09:37 AM
05/21/08 09:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah 3.91's and even 4.10's aren't THAT big of a deal. I often drove 50+ miles one way to race w/ 3.91's and 4.10's. When you build one of these cars MPGs should be the last thing on your mind. Choose the gear that will BEST work with you set-up.
Re: Best Street Gear Ratio?? -HELP [Re: A4SixtyNineRR] #60644
05/21/08 10:05 AM
05/21/08 10:05 AM
Kirkland, Washington
Pacnorthcuda Offline
With a short tire (something less than 27-28") I would take the 3.55. 28 and above, I would opt for the 3.73.
But this is a question of preference, there really is no right or wrong answer.
Re: Best Street Gear Ratio?? -HELP [Re: Pacnorthcuda] #60645
05/21/08 11:12 AM
05/21/08 11:12 AM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
Not to high jack but would a swap to a 3.73 or 3.91 from a 3.23 be noticable and how much will it affect the top end?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Best Street Gear Ratio?? -HELP [Re: 73cuda340] #60646
05/21/08 11:26 AM
05/21/08 11:26 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
3.55 (or 3.54 in danas) are the best all around ratio for a street driven Mopar. Especially with the price of fuel. Any lower (higher numerically) is just crazy.
Re: Best Street Gear Ratio?? -HELP [Re: Kudakidd] #60647
05/21/08 11:30 AM
05/21/08 11:30 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I have 4.10s - with the 3800 stall converter highways aren't the best spot for it.
Ride eternal, shiny and chrome
Re: Best Street Gear Ratio?? -HELP [Re: Kudakidd] #60648
05/21/08 11:31 AM
05/21/08 11:31 AM
355's in my 69 roadrunner is just right
Re: Best Street Gear Ratio?? -HELP [Re: Dart 340] #60649
05/21/08 11:35 AM
05/21/08 11:35 AM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Again, I would love a 3:23 in a 742 if anyone wants to part with one.
Page 1 of 3 1 2 3
