BB Timing Chain and gears... #606234
02/06/10 05:48 PM
02/06/10 05:48 PM
tboomer Online work OP
tboomer  Online Work OP
What do you like and why?? I need to order a 3 bolt setup...
Re: BB Timing Chain and gears... [Re: tboomer] #606235
02/06/10 05:53 PM
02/06/10 05:53 PM
get the rollmaster timing chain with torrington bearing.great piece.imo. i believe nick at compuflow has the best price. i might also have an extra one if you want me to look.
Re: BB Timing Chain and gears... #606236
02/06/10 05:55 PM
02/06/10 05:55 PM
Just looking for opinions..When I find one I want...I will order thru Summit...Got a list that is getting bigger...
Re: BB Timing Chain and gears... [Re: tboomer] #606237
02/06/10 06:00 PM
02/06/10 06:00 PM
summit doesnt sell the rollmaster, its the best out there and priced right.
Re: BB Timing Chain and gears... #606238
02/06/10 06:02 PM
02/06/10 06:02 PM
ok...I gotta get the body done,too...Dang....I hate winter!!
Re: BB Timing Chain and gears... [Re: tboomer] #606239
02/06/10 07:21 PM
02/06/10 07:21 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I think I bought a jegs billet 9 keyway timing set with a torignton bearing.
Re: BB Timing Chain and gears... [Re: sturmenater] #606240
02/06/10 07:33 PM
02/06/10 07:33 PM
PA
moparacer Offline
moparacer  Offline
PA
That's what Ryan J got me for my Big Block.
Just be careful if the block had been line bored.
A stock length chain is really sloppy, We had to go with a .008 undersized on my block to get rid of the slack.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: BB Timing Chain and gears... [Re: tboomer] #606241
02/06/10 07:55 PM
02/06/10 07:55 PM
AndyF Offline
AndyF  Offline
I use the Cloyes hex-a-just. I can adjust the cam timing without removing the timing chain cover that way. And my roller button is designed to fit the hex-a-just.
