Re: Chrome Box
[Re: wmwalden]
#60525
05/21/08 10:29 AM
05/21/08 10:29 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Chrome boxes don't retard the timing at high rpm.
Orange boxes DO.
Orange boxes are also much more failure prone.
If you have to pick between the two, spend a couple extra bucks and get the chrome box. It's worth it.
But that said, when my pile ran mid 12's I once A/B tested orange/chrome boxes and saw no difference in ET, shifting in the 6000rpm range. It's very possible that certain combinations might actually run better with a high rpm timing retard than without.
Rich H.
Esse Quam Videri
Re: Chrome Box
[Re: 540challenger]
#60528
05/21/08 01:24 PM
05/21/08 01:24 PM
Posts: 5,439 So Cal
Sinitro
So Cal
i have been running with my chrome box and stock coil for about 3 years now no problem.
Me too.. Been running Chrome box, 0.25 Ohm resistor, Blaster coil... For 2 years, no issues...
Re: Chrome Box
[Re: Joshs68]
#60536
05/21/08 08:54 PM
05/21/08 08:54 PM
Posts: 1,032 Ohio
dobie
Ohio
Well, this is good to hear, as just today I picked up a chrome box from Summit.
1968 Plymouth Road Runner
383 4 speed
Re: Chrome Box
[Re: 426lloyd]
#60537
05/21/08 09:00 PM
05/21/08 09:00 PM
What retards the timing in these boxes is the resistance in the circutes. The old Boxes made in US are OK but the newer ones dont perform as well. They are made by the lowest bidder China. The FBO Box is made with the highest quality circuts and parts. Thats why they are better and because they use better parts they can run Higher voltage and that makes for a hotter spark.
Re: Chrome Box
[Re: ZIPPY]
#60538
05/21/08 11:06 PM
05/21/08 11:06 PM
just the reason why i run orange ecu's. i like a little high rpm retard. makes for better mph, and little chance of detonation. and yah.. should be good with a 1/4ohm resistor.
Re: Chrome Box
#60541
05/22/08 10:09 AM
05/22/08 10:09 AM
ZIPPY
S.E. Michigan
