Page 4 of 4 1 2 3 4
Re: how much hp will 3/8 fuel line handle? [Re: dizuster] #605020
02/08/10 02:03 PM
02/08/10 02:03 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Have you ever drove a 1/2 full fuel tank with no baffles, Picture a long cyl 1/2 full of fuel goin 55 mph and step on the brake, there is quite a large surge from the fuel weight slowing down from 55 pushing on the front of the tank, the larger the dia and length of the tank the harder the push, now fill the tank full so there is a pressure in all directions and step on the brake, the surge is gone but there is a steady pressure from the fuel weight, a tank full of fuel will be harder to stop than an empty one, I would think it be the same on acceleration
Re: how much hp will 3/8 fuel line handle? [Re: dizuster] #605021
02/08/10 02:50 PM
02/08/10 02:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
I just don't see why you think the mass of the fuel can be ignored.
it does not apply to this discussion, period
again...fluids exert force in all directions. the additional loading from the mass is distributed to the WALL of the container (hose, tubing etc.) not the bottom or in this case pump discharge.
look at it this way... you have two tanks both 30' tall full of water. one is ten feet in diameter the other is 150' in diameter. put a pressure gauge at the bottom of both tanks and the reading will be the same 12.99 PSI. what WILL be different is the wall thickness of the larger diameter tank will have to be greater than the smaller tank because the additional mass of the much greater quantity of water is exerted on the WALLS of the container not the bottom. the ten foot tank would probably hold up being made of sheet metal, try that with the big one and you'll have a flood.
Re: how much hp will 3/8 fuel line handle? [Re: jamesc] #605022
02/08/10 03:15 PM
02/08/10 03:15 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
In your tank example the head pressure is the same but now lets try to quickly lift the two tanks off the ground <accelerate> which tank would be harder to move or require more energy?
Re: how much hp will 3/8 fuel line handle? [Re: emarine01] #605023
02/08/10 03:26 PM
02/08/10 03:26 PM
jamesc Offline
jamesc  Offline
obviously the larger tank but that has nothing to do with the pressure observed at the bottom of the tanks. accelerate both tanks at 2G and the pressure measured at the bottom of both tanks will be 25.98 pounds. what's being discussed is the increased load on the discharge of the pump due to line diameter and acceleration. the diameter has NO effect the length, rate of acceleration and fluid properties does. trust me it doesn't matter if the line is 5/16" or 2" the pressure change at the pump discharge due to acceleration will be the same.
Re: how much hp will 3/8 fuel line handle? [Re: jamesc] #605024
02/08/10 03:40 PM
02/08/10 03:40 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Ok, I see your point, but what about volume?
Re: how much hp will 3/8 fuel line handle? [Re: jamesc] #605025
02/08/10 03:46 PM
02/08/10 03:46 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Everytime this comes up we get into the same pointless discussion about fluid dynamics, you'd think we would have a sticky or tech archive post about this.
Drag Stripper and Jamesc are correct, this is a simple fluid dynamics problem. Pressure = density * acceleration* height.
Like it's been said 1000 times before, size of the line has nothing to do with the pressure due to acceleration.
Re: how much hp will 3/8 fuel line handle? [Re: CokeBottleKid] #605026
02/08/10 05:37 PM
02/08/10 05:37 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
This fluid dynamics thing is not that easy to understand < at least not to me> you guys are saying that the dia of the line does not make a difference psi, so a 1" pipe that is 100ft tall will take the same energy to lift as a 2" pipe 100ft tall, but what about the amount < volume> of liquid coming out the end? If ya read all the fuel pump guys versions for the need of a larger fuel system it kinda makes sense, can some one link together both pressure and volume as related to a racing fuel system? As is, it seems to me that a small pump with a large hose should work for the most part, so why are we buying large pumps? I started out with 2 Holley reds with 2 3/8 fuel lines feeding a 850 dp Holley and just about every one busted my chops about it
Re: how much hp will 3/8 fuel line handle? [Re: emarine01] #605027
02/08/10 08:45 PM
02/08/10 08:45 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
EMarine, the concept is hard to grasp I admit!
I too was skeptical, it went against what I felt was common logic. But fluid dynamics have thier own logic ways of working.
In your example the 2" diameter 100" column of fuel would have more mass. But the PSI pressure at the bottom would remain the same for both diameter pipes. The difference in mass of the 2 columns wont make a difference.
As a Example, take a 100 gallon Fish tank that has alot of water mass. Run a 1/4" diameter hose connected from the bottom of that tank up the side of it to the top.
Fill that 100 gallon Fish tank with alot of water mass and see what happens to the Low mass 1/4" column hose.
Will the Large Mass volume of the 100 gallon tank force water to gush out of the low mass 1/4: tube??
No, It will self level itself to the tanks water level. Why is that when you have that 100 Gallon mass? Fluid Dynamics!
To answer your question about Volume. The Pump works against pressure not mass. With both pipes having the same PSI but different Diameters.
Once fuel starts moving, line friction comes into play. The Faster the fuel moves, the more line friction and the more pressure is created in the line. Smaller lines if to small for the pump will create more resistance to any pumps rated flow vs a bigger line.
The bigger lines extra fuel mass will have no effect on the pumps abilty to flow its rated Volume. To small a line or too many turns and orifices will. mike
EDIT!!! Id Like to thank Jamesc, RobbMC and Firefighter Ron For Schooling me on this in the past!
Cokebottle kid I dont think discussions like this are ever Pointless.
Re: how much hp will 3/8 fuel line handle? [Re: dizuster] #605028
02/08/10 08:50 PM
02/08/10 08:50 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
And who said that the mass of the fuel could be ignored? NOBODY! FYI: Density (one of the 3 terms in the applicable equation) is the ratio of mass to volume. The whole point is that the AREA of the fuel line (diameter, effectively) doesn't have any affect on the pressure generated by accelerating the fuel. Also keep in mind that the fuel line is attached to the vehicle and forces generated from acceleration are transferred to the vehicle through the attachment points.
Re: how much hp will 3/8 fuel line handle? [Re: Sport440] #605029
02/08/10 09:06 PM
02/08/10 09:06 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
Good example.
Technically speaking, it's not fluid dynamics, that example is of Hydrostatics since the liquid isn't flowing. For all skeptics, check out equations 2 and 3 here: http://en.wikipedia.org/wiki/Hydrostatics
Good post! This is what people should be concerned with AND THIS is where we're talking Fluid Dynamics.
Re: how much hp will 3/8 fuel line handle? [Re: @#$%&*!] #605030
02/08/10 09:22 PM
02/08/10 09:22 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Thankx for the help guys It took a few hits to sink in Maybe the guys sellin the monster fuel pumps should read this post
Re: how much hp will 3/8 fuel line handle? [Re: emarine01] #605031
02/09/10 07:50 AM
02/09/10 07:50 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
After much thought... I agree now that the diameter does not effect pressure or load on the pump.
Pressure is pressure. I was confusing the idea of accelerationg having an effect on the fuel vs. diamter having the effect.
To clarify my thinking. The harder the car launches, the higher pressure will be seen at the pump right?
But I now see that it has nothing to do with the diameter.
I kept thinking that the fuel column weight would be applied directly to the fuel pump vain (vane? sp?)
When I thought about the pump more specifically, I realized that the orfice size of the pump wasn't changing when the fuel line size changed. So if the same area of pressure from the pump port orfice wasn't changing (meaning area), how could the diameter of the fuel line possibly effect the pump?!?
That opened my eyes to the concept of diameter not effecting the force.
Thanks guys for taking time to explain. I know it must be frustrating some days, but at least rest knowing that you've opened another's eyes on the subject.
On more person now to fight old wive's tales about fuel line diameter!
Now I see why I got an "A" in statics, and only got a "B-" in fluids.
Re: how much hp will 3/8 fuel line handle? [Re: dizuster] #605032
02/10/10 05:03 AM
02/10/10 05:03 AM
Detroit, MI
Detroit, MI
Yaaa you sorta get it, however fuel pump orifice has little to do with it as well. The fluid pressure at the end of the line and thus at the pump outlet will be the same regardless, you can even size up the fuel pump orifice with line size changes.
Re: how much hp will 3/8 fuel line handle? [Re: CokeBottleKid] #605033
02/10/10 11:10 AM
02/10/10 11:10 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Oh no, I wasn't saying the fact that the orifice size didn't change explained it all. I was just making the point that thinking about the fact that the orifice size wasn't changing changed my whole thought process...
Page 4 of 4 1 2 3 4
