Re: turn signal problems! 69 Road runner front turn signal
[Re: MNobody]
#604527
02/05/10 12:57 AM
02/05/10 12:57 AM
Posts: 321 Rockford, IL
foz
International Diplomat
Rockford, IL
[Re: foz]
#604528
02/05/10 01:02 AM
02/05/10 01:02 AM
RapidRobert
bulb metal case to socket. Socket to body ground. If you have hazard flashers try it (the can) in place of the TS flasher can & see if you're good. EDIT you do have fire TO the large filament circuit in the dual bulb w the stalk "up" right?
[Re: foz]
#604531
02/05/10 11:27 AM
02/05/10 11:27 AM
RapidRobert
The hazards DO work at all 4 corners but that right side front just doesn't want to work in turn signal mode! Since the hazard work works, which is the same filament as the T/S, what specifically could it be?
Progress!. go to www.mymopar.com & find what color wire we're looking for and take a circuit tester (the one w the alligator clip on a wire and the probe w a long thin point) and stick it into the wiring harness connector coming out of the steering column & w the 2 connector halves still together stick it into the "out" wire to the RF large filament circuit & see if you have fire w the key on/stalk up of course. This will tell you if the prob is downstream from there (towards the firewall bulkhead & out to the bulb or if its up in the TS assy under the steering wheel. Might just pull the black bulkhead connector on the firewall apart & clean it real quick & might get lucky & be done w it since the bulkheads are so trouble prone. EDIT if from the st col harness connector downstream the hazard "out" wire to the RF large filament and the right front TS wire "out" to the same filament is the same wire & I believe it is then the TS assy under the steering wheel is looking likely. Holler when you find it.
[Re: RapidRobert]
#604532
02/05/10 11:32 AM
02/05/10 11:32 AM
foz
Rockford, IL
This retard(me) FORGOT to mention I replaced the forward light harness last night! The old original forward light harness was fine except for that front right turn signal issue!
I'll check out what you mentioned!! Thank you!
[Re: foz]
#604533
02/05/10 12:35 PM
02/05/10 12:35 PM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
Problem: right front(pass. side) front running light works but turn signal does not! Both rears work but kind of erratic, slow then fast and so on!
Could the turn sig. switch be bad somehow??
OR flasher issues???
I had the same issue with my 69 bee,and traced it to the turn signal switch. I believe NAPA has a repair part fot that, so you don't have to replace the entire switch assy.
[Re: foz]
#604535
02/05/10 03:03 PM
02/05/10 03:03 PM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Turn signal switch is all one unit. No replacement parts for it. Did it last month on the gtx. I had tail light problems.
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
[Re: Dr V]
#604536
02/05/10 03:09 PM
02/05/10 03:09 PM
Posts: 32,954 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Nope, you can buy a cancel cam to replace the bad one at most any parts store. It's the piece with the wire wiskers on it that the lever moves. I've replaced a bunch of them.
