Re: turbo 400 chrysler install ? [Re: grncpe] #604248
11/06/11 06:03 PM
11/06/11 06:03 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
a 727 would hold up fine 4 his application. just need a few good parts, steel billet drum, billet low/reverse piston, hardened band strut & a bolt in sprag. trans will last 4 years & years. stay safe, seeya.
Re: turbo 400 chrysler install ? [Re: rickraw] #604249
11/06/11 08:12 PM
11/06/11 08:12 PM
Wisconsin
roadguy67 Offline
roadguy67  Offline
Wisconsin
My trans builder's experience is that a torqueflite is fine as long as it's footbraked (no trans brake). If you're from the Chicago area, this guy built the torqueflites that were ran in the Sparticus car for years.
Re: turbo 400 chrysler install ? [Re: rickraw] #604250
11/06/11 08:22 PM
11/06/11 08:22 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
ATI coming news at SEMA claims
The next upgrade component is ATI’s 904/727 Torqueflite. One inherent problem with the Torqueflite transmission is that it wants to break the rear sprag on a hard launch.
ATI’s new rear sprag, which only utilizes one OEM inner element piece, is a totally new design that promotes more contact area then a conventional roller clutch.
It is retained in the case by three 1/4-inch dowels and four 1/4 inch shoulder bolts.
This allows the Torqueflites to easily handle 1000 lb/ft of torque
home of the
Sox and Martin Hemi Duster
Re: turbo 400 chrysler install ? [Re: HEMIFRED] #604251
11/06/11 08:55 PM
11/06/11 08:55 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
when will they be avaliable?? thanks.
Re: turbo 400 chrysler install ? [Re: rickraw] #604252
11/06/11 09:40 PM
11/06/11 09:40 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Wow this thread is still going? I have been using the turbo 400 for a year and a half now with no problems...
Re: turbo 400 chrysler install ? [Re: grncpe] #604253
11/06/11 11:10 PM
11/06/11 11:10 PM
Wisconsin
roadguy67 Offline
roadguy67  Offline
Wisconsin
Thanks for the update HemiFred!
Re: turbo 400 chrysler install ? [Re: grncpe] #604254
11/06/11 11:18 PM
11/06/11 11:18 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Shouldn't a 727 be just fine at this level of horsepower?
Re: turbo 400 chrysler install ? [Re: viperblue72] #604255
11/11/11 05:05 AM
11/11/11 05:05 AM
Chesterfield Twp. Mi.
John Burdine Offline
whats the story on driveshaft lenth when switching from a 727 to a th400?
Re: turbo 400 chrysler install ? [Re: John Burdine] #604256
11/11/11 02:13 PM
11/11/11 02:13 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
If I remember correctly, it's about a 9" difference in length between the two transmissions. Driveshaft for T400 will be longer.
Re: turbo 400 chrysler install ? [Re: grncpe] #604257
11/11/11 02:26 PM
11/11/11 02:26 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i think you have other issues.Heavy car?...727s are better then that..my 9.60 car 1.30 60foots with brake and stock drum no problems 15 years,just stay on top of it and it should hold up fine
