trans swap Qs #603295
02/04/10 12:40 AM
02/04/10 12:40 AM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
anyone here ever do a T5 swap onto a smallblock?
specifically a Magnum? I just bought a Quicktime bell and THEN found out they make all theirs to work with factory 130 tooth flywheels; a Magnum 318 one is 143 teeth and req'd if running factory type computer etc.
Re: trans swap Qs [Re: volaredon] #603296
02/04/10 03:51 AM
02/04/10 03:51 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
soecifically a Magnum? I just bought a Quicktime bell and THEN found out they make all theirs to work with factory 130 tooth flywheels; a Magnum 318 one is 143 teeth and req'd if running factory type computer etc.
if you go over to for A bodies only and do a search there are a few postings on this matter,,it will take some inventive imagination to make it work with a stick shift and the injection,, some one over on that board has modified a fly wheel ,but dont think they are using a quick time shield,,maybe the guys at street and performance have a conversion for the sensor on the rear of the magnum motor to adapt it to the front,,,this conversion seems diffacult with a stick,,good luck
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
