Page 2 of 3 1 2 3
Re: 500" Engine Build 440 Source? [Re: HemiDave] #602150
02/05/10 02:47 PM
02/05/10 02:47 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
get the Stealth heads (they will be fine on the street)
They're gonna choke that poor thing !!
Re: 500" Engine Build 440 Source? [Re: Stanton] #602151
02/05/10 02:52 PM
02/05/10 02:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Depends on how he plans to use it.. If he plans to spin it to 6-6500 rpm's then yeah the Stealths will choke it but it he's willing to accept that it makes gobs of torque up to around 5200 rpm's & gears the car to use that torque than he'll have a engine that should live a long life & offer very respectable performance...
Re: 500" Engine Build 440 Source? [Re: 1_WILD_RT] #602152
02/05/10 03:04 PM
02/05/10 03:04 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I have the cam you mention in my 440. You can afford to up the compression if you're using that cam. I have 11.5:1 compression ratio and run the car on 93 octane pump gas with no problems.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: 500" Engine Build 440 Source? [Re: 1968RR] #602153
02/05/10 03:14 PM
02/05/10 03:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Quench Explained....
Take a coffee can ˝ full of gasoline burning with slow flicking flame. Strike the can with a baseball bat and you have what I would call a “fast burn”, much like what we want in the combustion chamber. The fast burn idea helps our performance engine by shortening the overall burn time and the amount of spark lead (negative torque) dialed in with the distributor. If you go from 36 degrees total to 32 degrees total and power increases, you either shortened the burn time or just had too much timing dialed-in in the first place. If you have really shortened the burn time, you won’t need so much burning going on before Top Dead Center. Now you can retard timing and increase HP. Did you ever have an engine that didn’t seem to care what timing it had? This is not the usual case with a fast burn combustion but an old style engine with big differences in optimum timing cylinder to cylinder will need 40 degrees of timing on some and others only need 26 degrees. If you set the distributor at 34 degrees, it is likely that 4 cylinders will want more timing and 4 cylinders will want less ( V-8). Moving the timing just changes, which cylinders are doing most of the work. Go too far and some cylinders may take a vacation. Now what does quench really do? First, it kicks the burning flame front across and around the cylinder at exactly TDC in all cylinders. Even with spark scatter, the big fire happens as the tight quench blasts the 32 degree old flame around the chamber. Just as with the coffee can, big flame or small flame, hit it with a baseball bat and they are all big instantly. The need for custom cylinder-to-cylinder timing gets minimized with a good quench. The more air activity in a cylinder you have the less ignition timing you are likely to need. When you add extra head gaskets to lower compression you usually lose enough quench that it is like striking the burning coffee can with a pencil. No fire ball
This was written by By John Erb & I copied it from a really good article here..
http://www.kb-silvolite.com/article.php?action=read&A_id=39
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602154
02/06/10 04:58 AM
02/06/10 04:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
so 915 with .040 quench what compression can I run and still use pump regular or premium?
About 9.5:1 with the steel heads.
So is 10.5 good with stealth heads and running 93 pump ??? Yes !
My 440 is stock stroke and .030 over (446) and I use the MP .557 solid cam. I use 906 open chamber heads that have been milled some and I have the KB quench pad pistons. I run right on 10.0 comp and at 37 total timing thats all in by 2000 rpm I have no ping at all with my iron heads. So an aluminum head eng using 11.0 with the right cam wil run fine on 93 pump. At 10.5 on aluminum heads you will be fine.
Ron
Re: 500" Engine Build 440 Source? [Re: 383man] #602155
02/06/10 08:18 AM
02/06/10 08:18 AM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I've been trying to do some homework and I spoke with Edelbrock tech support about their heads. They stated I would not be able to run their heads due to the spark plug angle interfering with the superstock manifolds.
I'm beginning to think running aluminum may be a problem. Not quite sure if aluminum can support the weight of the manifolds. 440source said there would not be a problem. I calculate about 10.6 cr with the source heads and their 80cc chambers. That is a little higher than I'd like to go! Anybody know if aluminum can support the weight?
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602156
02/06/10 10:41 AM
02/06/10 10:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The aluminum heads will be fine with the heavy manifolds.My stealths on my 440 run at 6800 and are still pulling when I shift.Rocky
Chrysler Firepower
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602157
02/06/10 12:29 PM
02/06/10 12:29 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
The stealths have helicoils in the exhaust bolt holes so that really basically turns a 3/8" bolt into nearly a 1/2" bolt which does wonders to spread the load. I wouldn't worry about it.
Re: 500" Engine Build 440 Source? [Re: Stanton] #602158
02/06/10 01:27 PM
02/06/10 01:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And since Stealths are actually 84cc the compression ratio will be closer to 10.2 or 10.3...
Re: 500" Engine Build 440 Source? [Re: 1_WILD_RT] #602159
02/06/10 02:45 PM
02/06/10 02:45 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Randy, thanks for the interesting read. I let my builder put the 88cc eddys on my 451 low deck w/ the 440 source stroker kit & am worried about having no quench. He says its zero deck, but I'm tempted to mill the heads. I've read that CNC ported stealths flow pretty well, but would the small chamber eddys w/ CNC porting be better for his 500 build? Would the Max Wedge exhaust limit the power?
Re: 500" Engine Build 440 Source? [Re: 1_WILD_RT] #602160
02/06/10 02:45 PM
02/06/10 02:45 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I like the Stealth heads with that build. They run so close to the Eddys on all the flowbench tests I've seen, that its reasonable to assume the performance will be nearly identical. The straight plugs are a must with the manifolds. And mostly, your build has a very stock look with the dual plane manifold and stock exhaust manifolds, the stealth heads will allow that motor to look nearly completely stock, and run like a banshee!
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602161
02/06/10 03:00 PM
02/06/10 03:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You can get the Eddy head with straight plugs. They are the "Mopar" head with a 452 casting #.
Re: 500" Engine Build 440 Source? [Re: BSB67] #602162
02/06/10 04:05 PM
02/06/10 04:05 PM
BSB67 is that an open or closed chamber?
Re: 500" Engine Build 440 Source? [Re: RapidRobert] #602163
02/06/10 05:01 PM
02/06/10 05:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Closed, advertised as 84 cc.
Re: 500" Engine Build 440 Source? [Re: BSB67] #602164
02/09/10 02:40 PM
02/09/10 02:40 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Looks like the mopar aluminum heads are ideal, exactly like factory cast.
Are the exhaust ports and height same as factory for the 440Source Stealth heads?
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602165
02/09/10 03:12 PM
02/09/10 03:12 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Yes. They look EXACTLY like factory heads...thus, the 'Stealth' moniker.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602166
02/09/10 03:40 PM
02/09/10 03:40 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Wishfull thinking.
http://chucker54.stores.yahoo.net/bigblalcocyh.html
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602167
02/09/10 08:22 PM
02/09/10 08:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
They look like the Eddys, but say Mopar.
Re: 500" Engine Build 440 Source? [Re: BSB67] #602168
02/09/10 08:32 PM
02/09/10 08:32 PM
So Cal
So Cal
Exactly! That's because they are made by Edelbrock for Mopar Performance.
Re: 500" Engine Build 440 Source? [Re: HemiDave] #602169
02/10/10 11:18 AM
02/10/10 11:18 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Dave [/quote)
I dang sure dont agree with this statement. Im running 10.5 with open chamber iron heads, without any detonation problems. No quench whatsoever. Of course I have a decent sized cam, 259@.050, but 9.5 is on the conservative side.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Page 2 of 3 1 2 3
