Re: Griner tb valvebody [Re: stevehiss] #600860
02/02/10 06:19 PM
02/02/10 06:19 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Well im a little low on cash now.
Re: Griner tb valvebody [Re: sshemi] #600861
02/02/10 06:59 PM
02/02/10 06:59 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
For an 800 HP application that tranny will last just fine. I don't know the seller but that is a Tranzact VB and I had great luck with them.
The only issue I see is you need a billet front drum for absolute sure. A billet front planet and a hardened rear shaft would be a plus but you do not need it.
You commented on the bolt in sprag. That is not necessarily a good thing. A bolt in sprag is installed either because someone is told they need one or they spun the stock one and ruined the holding capability of the case when the old one spun.
Leon
Re: Griner tb valvebody [Re: Leon441] #600862
02/02/10 08:03 PM
02/02/10 08:03 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
True Leon but that is a 6 bolt 16 element unit which is an upgrade. That still doesn't say anything for the case condition but the sprag itself is a much better than stock unit.
Re: Griner tb valvebody [Re: Leon441] #600863
02/03/10 07:11 AM
02/03/10 07:11 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Leon
sure it will hold up for 800 hp but for how long?
What i want in a tranny is billet, billet,billet so i dont have to worry about it comming apart.
I also want low maintenance.
The output shaft might be a little overkill becouse of a light chassie.
When i tore it apart the pumpcoverbolts where loose and also the front band, so im thinking it probably had good drum and cluthes and band but someone replaced it before it was sold.
Also it was full of water as if someone washed it while the front was out.
The water led to a stuck front servo and a hard to turn over rear bearing.
Sure noproblem to fix but the reason i bought this trans was to save some money and work.
Guess i didnt save any of it.
Its as they say cheap and good cant be used in the same sentence(sp)
Re: Griner tb valvebody [Re: sshemi] #600864
02/03/10 07:27 AM
02/03/10 07:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem for you off shore guys is the shipping
cost so you would most likely be better off buying
new every time from a known company.... unless you
know the guy and can see good pics....... JMO
Re: Griner tb valvebody [Re: MR_P_BODY] #600865
02/03/10 08:01 AM
02/03/10 08:01 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mopar Enthusiast - How to build a bulletproof 727!
You might have to sign up - it only takes a second - and there is an article that describes the details of keeping a 727 alive and keeping your feet from being blown off!
