F body headers #60074
05/20/08 08:54 AM
05/20/08 08:54 AM
San Diego, CA, United States
Texas_Charger Offline OP
I have heard that due to the torsion bar location on the F-bodies you can run small block A/B/E body headers on your small block F-body.
Is this true?
I dont actually own an F-body, mine's a J body, but what works on one should work on the other. It sure would be easier to find A/B/E body headers than F body. Also, if they do fit, how low will they hang?
Thanks in advance.
1971 Dodge Charger SE 470/727/3.91 Suregrip
2016 Dodge Challenger Hellcat, 6-speed
1980 Pontiac Trans Am, Y84, WS6
2002 Ram 2500 Cummins/6-speed/2WD/QC
1971 Ford F-350 Ranger
Re: F body headers [Re: Texas_Charger] #60075
05/20/08 09:23 AM
05/20/08 09:23 AM
Iowa
3
318Bruiser Offline
318Bruiser  Offline
Iowa
Here is a post I received about that same question about a year ago,"Use the $139 Heddman 78050's...They do hang below the draglink so watch the potholes on the street, but they fit fine. On my '80 Mirada (360, power steering) they fit perfect and I didn't have to make a single ding in them at all." Hope that helps some.
Re: F body headers [Re: 318Bruiser] #60076
05/20/08 12:32 PM
05/20/08 12:32 PM
Can you tell me about how far they hang below the crossmember?
Also, Jegs sells headers for F bodies: JEGS 30080 and they also fit B/A/E bodies as well. They're alot cheaper, $109.95, than the Hedmans. These should work, right?
Re: F body headers [Re: Texas_Charger] #60077
05/20/08 12:42 PM
05/20/08 12:42 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm using Hooker F body headers on my M body Fifth Avenue. They fit great and didn't require any modifications with a hammer to fit. They actually clear everything. Gaining access to plugs #5 and #7 can be a pain and so can getting to the rear header bolt on the driver's side. They hang a little low, but I haven't had a single problem with that in over 2,000 miles since installation. Three tubes go over, and one goes under.
Here is a gallery of pictures you can judge ride height off of. No really up close shots of the steering drag link though. If you need some I'd be more than happy to take them tonight. PM me if need them.
http://picasaweb.google.com/MoparMullins/070822ExteriorAndEngine
Re: F body headers [Re: MarkZ] #60078
05/20/08 01:39 PM
05/20/08 01:39 PM
That should work great. My Imperial sits pretty low on the nose, so that's why I was wondering. I can raise the torsion bars if I have to. Are those Competition or Super Competition headers? I'm a high school student with pretty shallow pockets, so I'm trying to go with the cheapest combination possible, as long as they'll fit and flow.
By the way, that's a slick Fifth Avenue
Re: F body headers [Re: Texas_Charger] #60079
05/20/08 04:00 PM
05/20/08 04:00 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
my 5th has the el-cheapo hedmans, all comments the same as mark's but I haven't smashed the "under" tube in over 15000 miles of driving on michigan roads, and my car's front end is set about 1/2" lower than stock, with stock height (27" tall) tires....
2017 Grand Cherokee Overland
Re: F body headers [Re: Texas_Charger] #60080
05/20/08 04:55 PM
05/20/08 04:55 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
That should work great. My Imperial sits pretty low on the nose, so that's why I was wondering. I can raise the torsion bars if I have to. Are those Competition or Super Competition headers? I'm a high school student with pretty shallow pockets, so I'm trying to go with the cheapest compination possible, as long as they'll fit and flow.
Thanks for the compliment! They're Competition headers, 1 5/8" tubes. I ordered the ceramic coated ones and they sure do look nice in the pictures, but fast forward to next spring and a few thousand miles and they're starting to rust from top to bottom. Next time I'll save the money and get them bare.
Re: F body headers [Re: MarkZ] #60081
05/20/08 06:26 PM
05/20/08 06:26 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I have TTI headers on my f body and they were a breeze to install. Big money though but I think they are worth it. They don`t hang below the drag link and have very easy access to the spark plugs. Mike
Re: F body headers [Re: mopars4ever] #60082
05/20/08 06:46 PM
05/20/08 06:46 PM
Hmmmm, if it was a perfect world, I'd get tti headers, but then again...
Thanks for the pictures and advice! So all you guys with F/J/M bodies, what did you do for exaust beyond headers? I know that the gas tank is in the way, but I'd like to put NASCAR-style side pipes anyway. What do you think?
Re: F body headers [Re: Texas_Charger] #60083
05/20/08 07:12 PM
05/20/08 07:12 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it's gonna be loud and drone. I'd move the tank over 1 strap and use the summit A body kit, or custom make your own big single. I used a flowmaster Y merge collector, 17769 dynomax muffler (3" in/out) 3" dynomax race bullet in the tailpipe for a resonator, and some mandrel bends to make a 2.5-2.5" to 3" single exhaust.
Re: F body headers [Re: patrick] #60084
05/20/08 07:23 PM
05/20/08 07:23 PM
Loud is good!
<17 years old>
Re: F body headers [Re: Texas_Charger] #60085
05/20/08 08:50 PM
05/20/08 08:50 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Heddman small block shortys work also for super easy install. No clearnace issues what so ever, a breeze to install but they are pricey like $280 for painted though. And you have to have a shop make you some curved up head pipes to connect to them. Not really a do it yourself deal because they are more like a manifold style hookup. But absolutely no clearance issues though.
Re: F body headers [Re: mopowergtx] #60086
05/20/08 10:31 PM
05/20/08 10:31 PM
My brother and I have Hedman shorties on our C-body '76 New Yorker and they were a pretty easy install. The only problem was with the starter, and luckily we had a ministarter lying around, so they cleared.
Re: F body headers [Re: Texas_Charger] #60087
05/21/08 10:31 AM
05/21/08 10:31 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Loud is good!
<17 years old>
You'll like it for now, but it'll wear on you, trust me (25 years old). I've got a pair of Flowmaster 40s that dump down right in front of the axle. The drone is very annoying. A balance pipe will be going in and I'll be moving the tank over to run the pipes back this spring. In the end I'll most likely wind up changing mufflers.
Re: F body headers [Re: mopars4ever] #60088
05/21/08 11:40 AM
05/21/08 11:40 AM
Endicott, NY
bnichols Offline
bnichols  Offline
Endicott, NY
rallyecharger which tti's did you use??
Re: F body headers [Re: bnichols] #60089
05/21/08 11:55 AM
05/21/08 11:55 AM
md
md
IIRC, TTI told me to use the B body headers but I would call them to make sure since I bought them a couple years ago and they may have made some changes since then. They are the best headers I have ever owned. No leaks and they fit very well. Starter access is good. I did use a mini but I think a regular starter would fit fine. Changing the plugs are a breeze with no burnt wires. I installed the right side in about 10 minutes no lie. The left side took a little more work but I think it took about a hour at the most. Just follow the instructions included. One thing, if you have a automatic console floor shifter you may have to redo the one linkage rod. Nothing major. Mike
P.S. The hardest part was removing the old headers. I ended up cutting them off with a saw.
P.S.S. I have 3 inch Dynomax ultra flo`s and I love them.
