Tube chassis body mount question #600533
02/01/10 12:14 PM
02/01/10 12:14 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
I planned on running stock glass front and rear but I was concerned with the vibrations of the body being solid mounted to the chassis, so should I use a poly mount or am I just being paranoid? And when cant you run glass ET wise? I never saw it in the rule book.
Jason
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: Tube chassis body mount question [Re: haddixj] #600534
02/01/10 02:04 PM
02/01/10 02:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Jason
We mount all fiberglass parts the same as metal parts.Let it all "shake" together.
Re: Tube chassis body mount question [Re: B G Racing] #600535
02/01/10 02:33 PM
02/01/10 02:33 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
Sorry my post was a little vague, I was talking about the front windsheild and rear
Re: Tube chassis body mount question [Re: haddixj] #600536
02/01/10 08:40 PM
02/01/10 08:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It wont be a problem... if the chassis is strong it
wont flex much at all... much less than a production
body... dont even worry about vibration... but I mount
the glass with either the stock rubber or put in butle rubber
under it so the glass isnt against any metal
Re: Tube chassis body mount question [Re: MR_P_BODY] #600537
02/02/10 01:58 AM
02/02/10 01:58 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have real glass in the front and back windows.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Tube chassis body mount question [Re: go green] #600538
02/02/10 01:02 PM
02/02/10 01:02 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
thanks for your help
this is where the car sits as of last night
Re: Tube chassis body mount question [Re: haddixj] #600539
02/02/10 05:40 PM
02/02/10 05:40 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Are you going to have the car done this year? will we see you at the track? looks nice what motor you running
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Tube chassis body mount question [Re: 65signet] #600540
02/02/10 06:37 PM
02/02/10 06:37 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
I will be out this year, hopefully summer the motor is a BBC.
