Re: Details....Details...Critique This 67 Engine
[Re: 1_WILD_RT]
#600204
01/31/10 10:14 PM
01/31/10 10:14 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Quote: --------------------------------------------------------------------------------
I got the paint from Supercar Restorations
The color looks spot on for 1964-1968 Race Hemi's, Street Hemi's, and Max Wedges, it's typically called "Race Hemi Orange". That's the first I've seen of thier paint, looks just as close as what Frank Badelson sells.
As far as nit picking your detailing job, pretty tough to do without being there, you definately have it very close, any small stuff would likely relate to paint application (bare areas, overspray, etc.) hose and belt markings, etc. Of course wrong oil filter, other noted missing componants you mentioned, and I think your alternator needs some help.
Scott, I started another thread to nit pick my problem areas. I need all the help I can get . I didn't have my alternator sent out and done, could you give me some pointers that I could do to make it more correct?
Thanks Dan.
I pulled this from the other thread as a lead in to save some typing.
Ok, on the alternator, the Stator (the bare steel looking part sandwiched between the front and rear case halves) should have a brownish gold color as they were coated with an insulating varnish when new, the rear case deatils aren't eveident in your pics but you should have date stamped/part#'d diodes as well as a ribbed style Torington center bearing plus other small screw plating details, also, most of them had colored splashes of inspection markings around the positive post area and the back side of the case. Jim Ridge fromDixie Restorations can likely help you on all that.
*BTW, R/T, his alternator bracket is fine
[Re: srt]
#600207
02/01/10 07:13 AM
02/01/10 07:13 AM
Posts: 2,655 western PA
mopar4ya
western PA
What happened to the carbs
There is gas in them . Was there any type of tab or bracket used to hold the choke tube in to the choke housing? Where could I get information on paint markings to do the engine,and for that matter the rest of the car and drive train.
Thanks Dan
[Re: mopar4ya]
#600210
02/01/10 10:51 AM
02/01/10 10:51 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Looks great Dan. The only things I see beside what has been stated already, and this is getting nickle/dime, there usually is a small amount of overspray on the valve covers right at the base. The engines were painted with the valve covers on and the taping off was hit and miss. The plug wires may also have paint marks slopped on them. Carb ID tags? When is it going in? Drop me a line to let me know how things are going. Holgar
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#600211
02/01/10 12:20 PM
02/01/10 12:20 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
How bout the fuel filters,were they suppose to be silverish looking ones.I thought the white ones came on race hemis.Looks great though .By the way though the paint on the exhaust manifolds,will burn right off the fist time you start the car, it did on mine
No, his filters are the correct style, all 1964-1967 Hemi's utilized plastic filters, the info I have shows blue ink stamped filters were street Hemi's, red ink stamped filters were Race Hemi & Max Wedge. The current plastic reproduction filters are not exact to originals, but they are allot closer than steel would be.
Concerning the exhaust manifold paint, yes, most would burn away pretty quickly, however most times there are areas around the exhaust flanges that don't so you will see remnants there in most cases.
I agree on the valve covers being installed when painted (masked off) and usually had the gaskets and a fine edge of paint near the very edges of the covers in areas (it was usually not very uniform). Also, often times the plug wires having traces of paint as well (that would have been covered in my generalized paint details comment).
The spark plug wires and distributor were installed as a unit pre-assembled, the paint was still wet when the wires were dragged around on the engine to route them and often picked up small smears of paint. Also, many plug wires have tiny speckles of paint indicating that they were in the line of fire when the engine was being painted, so it's likely that the wires were'nt far away when the engine was painted, possibly the distributor assembly was installed and masked off somehow. The fuel lines & filters were also installed when the engine was wet, often the lines & filters will have paint smears on them as well.
[Re: mopar4ya]
#600212
02/01/10 12:28 PM
02/01/10 12:28 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
There was a small metal strip that some choke assemblies had to retain the choke tube (I have them reproduced if you want one) but there are so few untouched survivor cars out there that had one I have never actually seen one that was original on a 66-70 Hemi car, I have however found them on other early 60's Mopar engines so they did exist. Here's what they look like.
Also, I can now get proper reproduction 66/67 carb tags (they have embossed verticle lines stamped into them). They are spendy though.
[Re: ScottSmith_Harms]
#600218
02/01/10 04:18 PM
02/01/10 04:18 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Hi Scott....question for you. "all 1964-1967 Hemi's utilized plastic filters, the info I have shows blue ink stamped filters were street Hemi's, red ink stamped filters were Race Hemi & Max Wedge." I'm doing a 1968 Hemi Dart clone.....done a lot of research on these things and I don't know off the top of my head ever seeing a Red Inked filter. Have any pictures?? Sorry for the high jack. The engine looks real nice and very correct, Good Job!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#600219
02/01/10 04:24 PM
02/01/10 04:24 PM
Troy
West Coast, CA
Is that Teflon Tape on the fuel fitting?? If it is you might want to remove it. Teflon tape and fuel don't work very well together.
Is that a red wire coming out of the Distributor?? Hard to see. Should be black with a red eyelet.
Nuts and carb studs... shouldn't they be black phosphate?
I'm not real good on 66-67 Hemis so I could very easily be wrong.
Very nice job!!
