Re: 1970 340 Fan & Clutch ?
[Re: scatcity]
#599876
01/31/10 10:56 PM
01/31/10 10:56 PM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
Sooooo, safe to say a 112 and a 216 would be correct for a 71 340 E body ?
Yes....though I prefer to call it the 2112 clutch....
As mentioned, A-bodies are different and use a smaller clutch & fan
[Re: YYZ]
#599877
01/31/10 11:38 PM
01/31/10 11:38 PM
Posts: 1,183 eganville ont
440beep
eganville ont
Fan Blade w/o A.C. V8 exc. 7-Blade 2863224 Fan Blade w/o A.C. w/318 4-Blade 2265034 Fan Blade w/o A.C. w/426 7-Blade 2863216 Fan Blade w/o A.C. w/440 5-Blade 3462150 Fan Blade w/A.C. w/198, 225 4-Blade 2780920 Fan Blade w/A.C. V8 exc. 7-Blade 2863216 Fan Blade w/A.C. w/318 5-Blade 3462150 Fan Blade w/Hi-Capacity w/198, 225 7-Blade 2863213 Fan Blade w/Hi-Capacity w/318, 340 7-Blade 2863227 Fan Blade w/Hi-Capacity w/383, 440 7-Blade 2963223
for 1971
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: 440beep]
#599881
02/01/10 03:52 PM
02/01/10 03:52 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
for 1971
Caution is required when using the parts catalogs for original application questions. I went through a number of broadcast sheets and compiled the following list. I have added full part numbers from GG's "white book" and it appears the "216" 7-blade fan was used to a greater extent than the list above would lead one to believe. I thought I had more A-body sheets.
1971 318 auto a-body w/o A/C FAN - 24 (2863224) & SPACER - 55 (1730155 1.40" spacer)
440 4-spd b-body w/3.54s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) HEMI auto b-body w/3.55s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 383HP auto b-body w/3.91s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 383HP auto b-body w/3.23s FAN - 24 (2863224) & SPACER - 10 (2120510 1.60" spacer)
HEMI 4-spd e-body w/3.54s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) HEMI 4-spd e-body w/4.10s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) HEMI auto e-body w/3.55s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) HEMI auto e-body w/3.23s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 440+6 4-spd e-body w/3.54s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 383HP auto e-body w/3.91s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 383HP auto e-body with A/C FAN - 16 (2863216) & SPACER - 60 (2863260 thermal clutch) 383HP auto e-body w/o A/C FAN - 24 (2863224) & SPACER - 10 (2120510 1.60" spacer) 340 4-spd e-body w/3.55s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 340 3-spd e-body w/3.23s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 340 auto e-body w/3.91s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 340 auto e-body w/3.55s & A/C FAN - 16 (2863216) & SPACER - 07 (3462107 thermal clutch) 340 auto e-body w/3.23s FAN - 16 (2863216) & SPACER - 12 (3462112 torque drive) 318 auto e-body w/o A/C FAN - 34 (2265034) & SPACER - 36 (2265036 2.20" spacer) 318 auto e-body with A/C FAN - 50 (3462150) & SPACER - 46 (1674746 1.72" spacer) 318 3-spd e-body w/o A/C FAN - 34 (2265034) & SPACER - 36 (2265036 2.20" spacer)
