spider gears #59979
05/19/08 10:12 PM
05/19/08 10:12 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
whats the disadvantage to welding spidergears
Re: spider gears [Re: 72d100] #59980
05/19/08 10:16 PM
05/19/08 10:16 PM
Kirkland, Washington
Pacnorthcuda Offline
You're making a locked rear end. No 'differential'. Same as a spool except NO WHERE NEAR as strong and is very likely to break (catastrophically).
Not advised. But some have gotten away with it.
Re: spider gears [Re: Pacnorthcuda] #59981
05/19/08 10:46 PM
05/19/08 10:46 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Its the way we do it on our dirt track cars. The keyword is dirt!
Re: spider gears [Re: earlybee] #59982
05/20/08 12:41 AM
05/20/08 12:41 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I agree with both of these posts.
I actually welded up a set once for a drag car, and then didn't have the courage to run them. I was way too scared of something going bad, and the wheels coming to a screaching halt at 100 mph.
Dirt only
Re: spider gears [Re: 72d100] #59983
05/20/08 08:03 AM
05/20/08 08:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
is there an advantage ???
i welded a set of spider gears but i did it to keep the axles from coming out of a car i'm junking because the 7.25 that is in it is wasted
Re: spider gears [Re: JohnRR] #59984
05/20/08 08:12 AM
05/20/08 08:12 AM
scratchnfotraction Offline
they need to be welded slow and with a nickle rod for cast iron
have not seen one hold up yet
but it was fun to break it,uslay going on and off the trailer,mud trucks and a few hooptees that was headed to the crusher
no way should you drive on the road with it IMO
if you need a locker,a mini spool is easy to do,a little cheaper and would hold up
if it junk you could try
