340 six pack idle #598436
01/30/10 02:58 PM
01/30/10 02:58 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
I'm just getting my six pack started for the first time. it will run at high rpm but not idle at all what could be the problem
Thanks Matt
Re: 340 six pack idle [Re: mattpar] #598437
01/30/10 03:09 PM
01/30/10 03:09 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Probably a big vacuum leak
Re: 340 six pack idle [Re: ScottSmith_Harms] #598438
01/30/10 03:11 PM
01/30/10 03:11 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
I plugged everything off and it still is dead on idle
Re: 340 six pack idle [Re: mattpar] #598439
01/30/10 03:16 PM
01/30/10 03:16 PM
Matt there was a thread a day or so ago on a six pack issue that was very comprehensive that may help you.
Re: 340 six pack idle [Re: RapidRobert] #598440
01/30/10 03:41 PM
01/30/10 03:41 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
new?old? or rebuilt carbs?
Re: 340 six pack idle [Re: mattpar] #598441
01/30/10 03:59 PM
01/30/10 03:59 PM
California
1970mopar Offline
1970mopar  Offline
California
make sure the outer two carbs butterflys are actually closed.
I've seen it alot where the linkage is not adjusted correctly holding the outer two carbs open -
Re: 340 six pack idle [Re: AARCONV] #598442
01/30/10 04:04 PM
01/30/10 04:04 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
rebuilt
Re: 340 six pack idle [Re: RapidRobert] #598443
01/30/10 04:06 PM
01/30/10 04:06 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
when you say thread, is that a question on this question and answer page?
Re: 340 six pack idle [Re: mattpar] #598444
01/30/10 07:07 PM
01/30/10 07:07 PM
yes, several days ago iirc
Re: 340 six pack idle [Re: RapidRobert] #598445
01/30/10 07:42 PM
01/30/10 07:42 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
aarcuda had a thread about an idle issue.
You need to make sure you have proper initial advance, outboards are closed, no vac leaks.
Basics first; timing, float levels, etc.
Re: 340 six pack idle [Re: RapidRobert] #598446
01/30/10 08:04 PM
01/30/10 08:04 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
thank you
