Starter relay amp rating #59786
05/19/08 04:41 PM
05/19/08 04:41 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
How much amperage can the stock starter relay handle ?
My car is getting the painless harness installed with several relays being put into the system(headlights, taillights, fuel, stereo system, wipers) I would like to pull power for them from a central source and the relay is nicely located. If it can't handle the draw, are there any other higher amp starter relays that I can use in the place of the stock unit ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Starter relay amp rating [Re: AlexP] #59787
05/19/08 04:46 PM
05/19/08 04:46 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
You can hook as much stuff as you want to the threaded stud. It`s the feed from the battery and the relay won`t care what`s on it.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Starter relay amp rating [Re: gamagoat6x6] #59788
05/19/08 11:01 PM
05/19/08 11:01 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
exactly
Re: Starter relay amp rating [Re: AlexP] #59789
05/20/08 01:42 AM
05/20/08 01:42 AM
The stud itself could probably survive a direct hit lightening strike.
Nice thing is...it's long enough to attach all kinds of extras.
I wouldn't worry about it.
Re: Starter relay amp rating #59790
05/20/08 08:18 AM
05/20/08 08:18 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
not 100% sure- but the starter relay thats on the firewall/fender has contacts for around 40-50 amps. so a Bosch 40 amp realy could do it- but if was me and I had to change it out to a newer one I would use two 40 amp Bosch relays in Parallel to do the job and not burn one out all the time!
Re: Starter relay amp rating [Re: 71_deputy] #59791
05/20/08 11:31 AM
05/20/08 11:31 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
only power going thru it is the starter
