Front tire wear #59783
05/19/08 04:29 PM
05/19/08 04:29 PM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
When the front tires on one of our cars wear on the inside, is it a sign that the toe-in, caster or camber is out of spec.?
Re: Front tire wear [Re: JeffRacerG] #59784
05/19/08 04:38 PM
05/19/08 04:38 PM
Kirkland, Washington
Pacnorthcuda Offline
Too much NEGATIVE camber.....but keep in mind, negative camber HELPS in handling, so a little more wear on the inside vs. the middle or outside is usually tolerated in the interest of good handling (think of it as 'rubber well spent', within reason of course)
Re: Front tire wear [Re: Pacnorthcuda] #59785
05/19/08 05:53 PM
05/19/08 05:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
First off caster does not cause wear. Negative camber wiil wear the inside if excessive. Not enough toe in or a toe out condition will greatly accelerate wear with negative camber. .10-.20 total toe in with -.75 to 0 will seldom wear excessivly on the inside. This assumes all components are in top shape. As the car goes down the road it is trying to push the tires outward at the front. If your static specs are correct and you have worn components it will toe out untill the slop is taken up. What started as .10 toe in could now be .50 toe out. Then you have wear and the first thought is to blame negative camber. All this being said I try to shoot for -1/4 to +1/4 camber, as much positive caster as I can get,.10 to .20 total toe in.
Doug
