Re: Copper Spray or HighTack - Shim Head Gasket?
[Re: 68LAR]
#596000
01/27/10 09:34 PM
01/27/10 09:34 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Are you using iron or aluminum heads??? I use the copper spray for iron heads, but use the high temp aluminum ceramic rattle can for aluminum heads.
...Permatex Gold works great on Iron, I've done the silver/alumimun spraybomb on Iron heads as well, great results,....Copper is tougher to pull a head later on though
[Re: VanishPt]
#596001
01/27/10 09:37 PM
01/27/10 09:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
these are al heads and an iron block
Go with the Silver/Aluminum ceramic header paint, spray the gasket fully both sides, install wet, no need to spray the block deck, or head, just the gaskets sides, have everything ready, torque to spec
