where do u find bearings for the torque shaft assmebly? #59426
05/18/08 11:29 PM
05/18/08 11:29 PM
BigAg Offline OP
BigAg  Offline OP
I went to slide in my torque shaft assembly tonight but can only locate 3 of the 4 plastic half bearings . I have no clue what happened to the 4th. Does anybody know where i can buy a individual one of these? Hopefully the 50 cent part won't cost 50 bucks. :P
I forgot to mention that the car is a 71 charger and the engine a 440.
Re: where do u find bearings for the torque shaft assmebly? [Re: BigAg] #59427
05/18/08 11:33 PM
05/18/08 11:33 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Are these the plastic shifter bushings like on a column shift setup? If so you can get them from the local dodge dealership.
Re: where do u find bearings for the torque shaft assmebly? [Re: Neil] #59428
05/18/08 11:53 PM
05/18/08 11:53 PM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: where do u find bearings for the torque shaft assmebly? [Re: CHRONiklyDEMONic] #59429
05/19/08 08:32 AM
05/19/08 08:32 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: where do u find bearings for the torque shaft assmebly? [Re: 64dodge572] #59430
05/19/08 08:40 PM
05/19/08 08:40 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I have 900+ plastic z-bar bearing 1/2 shells here in stock.
