Re: how can I unstick a locked up brake on my minivan?
[Re: pyp1000]
#594270
01/26/10 10:47 AM
01/26/10 10:47 AM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Have a look at the emergency brake cable end.
You may have to back off the adjuster to get home.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: WILD BILL]
#594274
01/26/10 09:30 PM
01/26/10 09:30 PM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We see this happen every once in a while on our stuff that sets awhile. Usually rocking the vehicle back and forth in forward and reverse while banging on the wheel with a decent sized hammer (like above) will break them loose.
Master, again and still
[Re: pyp1000]
#594277
01/29/10 08:42 PM
01/29/10 08:42 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Test drive it a little and see what happens. Sometimes the shoes simply rust to the drum and once you break them loose you are good to go......until the thing sets awhile and sticks again. If it must come apart now, the BFH may be your best friend to help persuade it off. If the drum is rusted to the center hub, then heating it up good may break the bond. Usually the shock of the BFH will get them off.
