acceptable tolerance for connecting rods??? #594134
01/25/10 10:46 PM
01/25/10 10:46 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Just received new H-beam rods and started measureing them.
What is the acceptable tolerance for length (c-c)
Whats needed for clearance in the bushed end w/.990 pins? .0015"?
Also what is max side clearance on big end. I measured these (big end) and they are approx .006" "thinner" than a used stock LY rod w/ 100,000 plus steet miles ('69 New Yorker)That means my side clearance is going to .012" more than stock. Is this a bad thing, or acceptable?
Thanks, Brian
Re: acceptable tolerance for connecting rods??? [Re: '72CudaRacer] #594135
01/25/10 11:12 PM
01/25/10 11:12 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i usually run the bushed end right at 0.0010" for "normal" use. usually aftermarket rods give you more side clearance, doesn't really seem to cause an issue if there a little loose. i would think new "quality" rods the CC should be right on.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: acceptable tolerance for connecting rods??? [Re: '72CudaRacer] #594136
01/26/10 01:57 AM
01/26/10 01:57 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
C-C should be within .005
Pin fit should be .0010 - .0015
No max on side clearance although a really loose number (> .035) will affect the oil pressure slightly.
Re: acceptable tolerance for connecting rods??? [Re: Mopar_Rich] #594137
01/26/10 10:50 PM
01/26/10 10:50 PM
Mooresburg, Tn
Mooresburg, Tn
the rods that I purchased are Ohio Crankshafts (made by whom?) are .002" from short to tall, but all are short (6.760" rods) from 6.7572" to 6.7592"
Just had a talk with my machinest, and was told not to over-think this. It's not a pro stock engine, the crank, pistons, block ect. are all going to be 2-5 thou off some where. I'm not going to spend enough to make it "perfect".
Guess he's right. Dang.
How close have you guys found your new stuff to be?
Thanks, Brian
Re: acceptable tolerance for connecting rods??? [Re: '72CudaRacer] #594138
01/27/10 02:32 AM
01/27/10 02:32 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Your machinist is correct. The spec you gave are fine. Noting is that perfect in that price range. It will not cause problems. I know the apparent large increase in the side clearance appears to be a concern. Many have found out that it has turned out to be a non-issue. Have some fun.
Damon
Re: acceptable tolerance for connecting rods??? [Re: mopardamo] #594139
01/28/10 11:57 PM
01/28/10 11:57 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks for the replys folks.I guess I was expecting new 6.760" rods to BE 6.760"
But I know that EVERYTHING has a tolerance (+/-).
At least my confidence is back.
Brian
