Steel hood braces.. #592659
01/24/10 12:33 PM
01/24/10 12:33 PM
tboomer Offline OP
tboomer  Offline OP
Would it be sahe to cut the hood braces off my 64? Just a little idea to take off some weight on the front...
Re: Steel hood braces.. [Re: tboomer] #592660
01/24/10 01:40 PM
01/24/10 01:40 PM
are you talking under the hood where the hood scoop would go. if so, yes it is safe. mines been done on my 63 MW plymouth.
Re: Steel hood braces.. [Re: tboomer] #592661
01/24/10 01:46 PM
01/24/10 01:46 PM
Truckville, the capital of NY
85_Ram_4speed Offline
On the other hand, if your talking taking out the entire under structure, and essentially leaving the edges and top skin, i say no---only from experience do i say that. It becomes a big flopping piece of metal, and i hacked up a few trying different things with them. The best solution but most time consuming one i came up with is various sized hole saws. Cutting out just in the area of a scoop is fine however. Oh, and when i did gut the entire bracing out from my Darts hood, i was suprised to see how light the bracing really was---i think the outer skin actually weighed more.
Outcast Dodge guy.
Re: Steel hood braces.. [Re: 85_Ram_4speed] #592662
01/24/10 02:13 PM
01/24/10 02:13 PM
tboomer Offline OP
tboomer  Offline OP
Like this 62...
Re: Steel hood braces.. [Re: 85_Ram_4speed] #592663
01/24/10 02:50 PM
01/24/10 02:50 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Wow that really takes me back, I haven't seen
Swiss cheese like that in years
Re: Steel hood braces.. [Re: tboomer] #592664
01/24/10 02:53 PM
01/24/10 02:53 PM
Oh, i see. That would probably work fine. I wonder how much just that piece weighs. Cut it out and report back.
Outcast Dodge guy.
Re: Steel hood braces.. [Re: B1KILLER] #592665
01/24/10 02:56 PM
01/24/10 02:56 PM
I got to say when i did that a few years back, A)I read to many old magazines as a kid, B) I always and still do like the look, and C) I was REALLY inspired buy another Moparts members car here---can you guess who?
Outcast Dodge guy.
Re: Steel hood braces.. [Re: 85_Ram_4speed] #592666
01/24/10 09:06 PM
01/24/10 09:06 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I cut the entire bracing out of mine on my 64 Dart (with the exception of about 2 inches around the edges ).I am not using hood springs though ,nor a hood latch .Mine is on my drag car and i am using the stock hinges plus i have it pinned in the front.I am also using a sealed scoop that is pressed firmly against the carb and i think it helps support it.It made a huge difference in the weight of the hood ,but its a little flimsy now.I'd say the whole structure that i cut out weighed proly 15-20 lbs easy ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
