Which headgaskets should I use? #59251
05/18/08 06:49 PM
05/18/08 06:49 PM
Connecticut
JFAbody Offline OP
JFAbody  Offline OP
Connecticut
putting in performer RPM heads on my 340. Which head gaskets should I use? any that I shouldn't?
72 Duster 340 4 Speed
Re: Which headgaskets should I use? [Re: JFAbody] #59252
05/19/08 09:45 PM
05/19/08 09:45 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Since I take it your just doing a head swap on a running motor then I'd use the .039 thick FelPro's permatorque's.
Re: Which headgaskets should I use? [Re: mopowergtx] #59253
05/19/08 10:04 PM
05/19/08 10:04 PM
If you are at zero deck & those heads are closed chambers the .039 ones mentioned would be just perfect. be sure & check the part #'s & thicknesses as the ones I have(felpro blue) are alot thicker than .039", there may be 2 different ones(.054)??,I'd have to go measure the ones I have.
Re: Which headgaskets should I use? [Re: RapidRobert] #59254
05/19/08 11:42 PM
05/19/08 11:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FelPro composite gaskets, # is either 1008 or 1009. Never a problem, even at 13.0:1.
