Take a look at these lobes
#590690
01/22/10 11:16 AM
01/22/10 11:16 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Looking at a few lobes for my 512 build. Take a look at the lobes and see which one(s) you like as far as a mix of power and durability. The cam is going in a street car that will see 1k or so a year on the street, so durability is a concern. Bullet .875 310 Adv [Email]272@.050[/Email] [Email]182@.200[/Email] .3910 lobe lift .016 lash Bullet .904 302 272 185 .4000 .009 Comp XTQ 298 272 184 .392 .018 Comp XX 304 272 182 .406 Lash not given Ultradyne NF.842 299 271 182 .3934 .016 Engle 272 182 .408 FWIW, the Bullet tech told me the Bullet .875 lobe listed above would be a poor choice, as its shown for a flat head. ![](/ubbthreads/images/graemlins/shruggy.gif) Combo is a 11 to 1 512, Ported BS heads,1.58 rockers, Vic Jr, 950 carb 3900 lb car, 3.73 gear. Im leaning towards the Comp XTQ, Bullet .904, UD NF .842 or Engle but looking for opinions
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Take a look at these lobes
[Re: Von]
#590691
01/22/10 11:53 AM
01/22/10 11:53 AM
Posts: 16,932 NC
440Jim
NC
Bullet .875
310 Adv 272@.050 182@.200 .3910 lobe lift .016 lash
Double check with Bullet. I think you got the lash wrong on the .904 lobe. I believe it is 0.009 x rocker ratio, so 1.5 x 0.009 = 0.014" lash
[Re: 440Jim]
#590692
01/22/10 12:00 PM
01/22/10 12:00 PM
Von
NE Oklahoma
I'll give em a call. I went back and checked and it is shown as .009 on the website. Thanks.
[Re: Von]
#590693
01/22/10 01:50 PM
01/22/10 01:50 PM
BradH
Quick comments off the top of my head(ers?): 1. Bullet lash specs are given for the lobe, not the valve; multiply x rocker ratio, plus add .002" for exhaust lash 2. I heard recently Engle has closed its doors, so don't get too set on one of their cams. 3. I run a smaller Comp XX 298/266 grind in my Challenger. A Comp tech rep (one who actually knows something) said I could run it from .016-.024". I think the XX has better RPM capability (and probably better reliability) than the XTQ. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: BradH]
#590694
01/22/10 02:07 PM
01/22/10 02:07 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
Drag car or street car. Bullet's got some nasty lobes (including the old UD NF series 904's that are violently quick....but too aggressive for street longevity.
512 I like a big intake ramp and would tend to use a faster ramp on the intake and a less intense (ex: maybe 4-6 degrees shorter at .200 for the relative same @ .050 ramp) exhaust lobe. I like both of the comp series lobes you call out, but Bullet is pretty much cutting edge right now on their mopar stuff. I'd talk to Tim Goolsby at Bullet and see what he picks for your exact combo and how you're gonna run it. Not much about your performance parameters/expectations here to go by...head flow and CR would help a ton. If the Bs's flow in the ~340 range by .550 I'd run something around 272/276 @.050 on 108 in at ~104-105...it'll fly and will pull hard even with the 3.73's. i'm guessing by the Vic intake it's a standard (or slightly larger) 906 size port....if it were a maxie/super Victor I'd put it in about 2 degrees earlier.
[Re: BradH]
#590695
01/22/10 02:36 PM
01/22/10 02:36 PM
Von
NE Oklahoma
I told to Engle this AM, so they are still open..at least today. LOL.
I wasted 30 mins or so on hold waiting for Comp this AM. Finally got through and the guy told me the XX and STQ lobes are way too violent for street use. I knew you were using the XX, so I didnt argue with him.
[Re: Streetwize]
#590696
01/22/10 02:41 PM
01/22/10 02:41 PM
Von
NE Oklahoma
Street car. Mine are in the 315 range at .550, 327 at .650. Yes,standard port and just a hair over stock port size.
[Re: Von]
#590697
01/22/10 02:53 PM
01/22/10 02:53 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
LOL that dude must be new, I talked to him the other day when I called to order a cam.... did'nt catch his name, but I can guarantee just based on what he said to me & you that it was same guy, he was not most intelligent person I've ever talked to, & he questioned everything I was telling him/asking them to grind....
If you ever call back as for, Kirk, Richard or Tim.... to avoid whoever that was you talked to.
