Re: 1/2" VS 3/8" Oil Pick-up?
[Re: Quicksilver440]
#589839
01/22/10 03:07 AM
01/22/10 03:07 AM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
23T ...all of that considered ... I would agree - the mod is worth doing. But WHY didn't Ma-Mopar have all HP motors with a 1/2" PU ?
because HP motors didn't make 500+ horsepower.
If you are using a horsepower # for oil PU size needs ...OK then. B U T the HEMI did not make 500hp dead-stock ...so why have it there?
#589840
01/22/10 03:13 AM
01/22/10 03:13 AM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Good question, Doc....it just appears that they settled for adequate. Doesn't really make sense, can't imagine tooling cost would be any different for a 1/2" setup. And what Quick said got me to thinking, if I remember right the Max-wedge blocks only used a 3/8" pickup. My dad ran a Stage III wedge in a late-model modified back in the 60's, I remember having bearing problems on a semi-regular basis turning 6200-6400 rpm laps. Wasn't a lot of oil-system tech back then,at least in our neck of the woods, but when we changed over to the Hemi, don't recall that we ever spun a bearing even though we were turning 300-400 rpm higher with a lot heavier piston and rod than the wedge. Could it have been the 1/2" pickup? I don't know, but it's just something to think about.
[Re: John_Kunkel]
#589842
01/22/10 06:13 AM
01/22/10 06:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Some pickup bosses are too thin to tap oversize, if the boss is sufficiently thick the reason to do this is because pumps are more efficient at pushing than they are at sucking; therefore, mods to increase the size of the suction side make sense.
You have to think of the suction side of the pump just like the intake side of the induction system.... its pressure(atmospheric pressure pushing it in). the pump creates the negative pressure zone, same as the piston does and everyone knows the work we do to the intakes on the heads
[Re: MR_P_BODY]
#589843
01/22/10 11:42 AM
01/22/10 11:42 AM
23T Hemmee
Franklin, TN
Doc said: just a deepened pan with a pickup that would "scare" most people here. It looked like someone heated and bend-up a piece of straight pipe and tacked on a screen. I've dones this a couple of times with a piece of black pipe straight from Home Depot, capped one end and filled with sand, then capped the other end, heated and bend to shape, took a couple of tries but the pipe is cheap. I did make an aluminum block for the screen section to increase the surface area, just a screen on the end of the pipe "is" a little scary... Great analogy, Mr. P.
[Re: 23T Hemmee]
#589845
01/22/10 02:24 PM
01/22/10 02:24 PM
Posts: 4,209 New York
polyspheric
New York
One of the shop-made Ramcharger mods was a 1" ID inlet welded to the stock pump body...
Boffin Emeritus
[Re: jamesc]
#589847
01/22/10 11:16 PM
01/22/10 11:16 PM
polyspheric
New York
Thanks - I can't find my picture, but the one I saw didn't look like that, different angle and point of entry.
Boffin Emeritus
