port mismatch not that big a deal breaker IMHO
the intake is gonna need a taller bracket for the throttle and kick down rod
on my LD4B/LD340 intake a stock truck q-jet 4-v bracket and linkage worked
I went to full manual VB on the 85 truck going to a 440 to loose the TPV linkage
IMO.a stock 4-v intake and a mopar q-jet would be the best,truck came with it,it will look stock and it all fits and work correctly
the LD intakes are the next best fit when it come to working the linkage
rpm air gap is a tall intake and will need the bracket and linkage
and hope it works correctly
if it dont you will toast the tranz in the long run by it not being adjusted correctly
DAMHIK
a Bouchillon kit would be the next step over the stock linkage
or use a full manual forward shift low band apply valvebody and then it no need for the linkage
good luck
