Page 4 of 5 1 2 3 4 5
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588640
03/25/10 11:31 PM
03/25/10 11:31 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
BIGDAD listed an Oklahoma auction in the WIW section that has an awesome parts car 69 VIP.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: JOES4FORTY] #588641
04/06/10 10:24 PM
04/06/10 10:24 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
started working on it again cleaning up the engine found E383 8 7 with a 2 below it... car is 828 SPD.. inside engine looks pretty darn clean hopefully it will run soon dan
tore down top of engine needs heads off now.... [Re: ph23vo] #588642
04/13/10 06:09 PM
04/13/10 06:09 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
one stiep forward 5 back... 2 ex valve stems are pitted away... might as well fix it while i,m in this far...
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588643
04/14/10 09:52 PM
04/14/10 09:52 PM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
I've always thought 69's were the sweetest C's.
I have a couple parts for a '69 for sale. Click the link in my sig.
Maggot
You can lead a gift horse to water, but you
can't look in his mouth.
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588644
04/15/10 12:54 AM
04/15/10 12:54 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
pulled the heads and #5 is fuel washed clean...may as well pull it now and see whats hiding... man this ones making me do it all... glad i didnt try and get it started! dan
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588645
05/31/10 07:09 PM
05/31/10 07:09 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
almost have all the hydraulics done, pulling the old motor tomorrow hopefully [weather] have the other 383 ready to drop in.. still need a few parts hopefully it will run soon... then next winter i,ll rebuild the orig engine! dan
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588646
06/16/10 11:07 PM
06/16/10 11:07 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
engine back in! finally! just need a wiring harness and an A/C idler pulley or just the bearing [anyone know where to get one???] dan
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588647
06/17/10 07:33 AM
06/17/10 07:33 AM
Virginia
rm23j8g Offline
rm23j8g  Offline
Virginia
That looks like a Holley on there...didn't it originally have a Carter AVS?
Re: tore down top of engine needs heads off now.... [Re: rm23j8g] #588648
06/17/10 10:39 AM
06/17/10 10:39 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Re: tore down top of engine needs heads off now.... [Re: CHRYCOFAN] #588649
06/17/10 10:58 AM
06/17/10 10:58 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
butch thanks a million! i knew someone must have them as every a/c car uses the same one pretty much! dan
Re: tore down top of engine needs heads off now.... [Re: rm23j8g] #588650
06/17/10 11:00 AM
06/17/10 11:00 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
nope! originally a holley 4 BBL... H code 383 w a/c dan
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588651
06/17/10 01:09 PM
06/17/10 01:09 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 B & C - bodies
Holley 383 4bbl 330hp
Carter AVS 383HP 4bbl 335hp
Re: tore down top of engine needs heads off now.... [Re: 6bblgt] #588652
06/17/10 09:03 PM
06/17/10 09:03 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
little more done today..got the engine sitting level finally... using a dr side schumacher mount and stock pass side..had to cut off the locating tab and large nut they use [bolt is larger diameter than stock]..that way i could retain the original bolt and that let the engine sit level.. did the p/s pump, valve covers, ex manifolds and brackets, maybe next week i can get under it and do exh starter etc... dan
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588653
06/22/10 09:18 PM
06/22/10 09:18 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
another with progress...
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588654
06/23/10 11:41 PM
06/23/10 11:41 PM
SC
V194 Offline
V194  Offline
SC
That's an Imperial style tire. GoodYear Power cushion I seem to recall. That exact size is a little too small for the 64-66 Imperials but perhaps used on the 67-70?
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: V194] #588655
06/24/10 11:23 AM
06/24/10 11:23 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
hey thanks not really sure as i cant seem to find any pics like it!
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588656
06/24/10 11:32 AM
06/24/10 11:32 AM
SC
V194 Offline
V194  Offline
SC
Here is the Imperial tire.
Goodyear Power cushion.
Re: tore down top of engine needs heads off now.... [Re: ph23vo] #588657
06/24/10 12:04 PM
06/24/10 12:04 PM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
Looking good!
Re: tore down top of engine needs heads off now.... [Re: ChryCoGuy] #588658
06/24/10 12:54 PM
06/24/10 12:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
dan can you post a picture of the pass side of the carb at manifold , curious to see what they did to the carb to make it fit a 69 intake .
engine looks good .
Re: tore down top of engine needs heads off now.... [Re: JohnRR] #588659
06/24/10 12:59 PM
06/24/10 12:59 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
john not sure what you are trying to see but lmk dan
