Blow thru carb or carb pressure box??? #588478
01/20/10 02:40 PM
01/20/10 02:40 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
There seems to be many more people using blow-thru carbs with a hat instead of a pressure box. Which is best?? Personal experiences??
Re: Blow thru carb or carb pressure box??? [Re: Blucuda413] #588479
01/20/10 02:43 PM
01/20/10 02:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
box is kind of a PITA... I bought one and went w/ an extreme air bonnet. You can push a good amount of boost thru a carb if it's prep'd right. I was only running 6 but have seen 12 and up. I had an 8psi pulley on but sold the car before I could give it a run. I'm sure it would have been fine. Just remember to boost reference your fuel pump and you'll be ok.
Coming soon!!!!
Re: Blow thru carb or carb pressure box??? [Re: Mr.Yuck] #588480
01/20/10 03:29 PM
01/20/10 03:29 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Blow through is the way to go... I plan to run 15 lbs.
Re: Blow thru carb or carb pressure box??? [Re: TheOtherDodge] #588481
01/20/10 04:33 PM
01/20/10 04:33 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The boxes dont seem to work as well. There is no real path for the air to take
Re: Blow thru carb or carb pressure box??? [Re: joshking440] #588482
01/21/10 12:47 PM
01/21/10 12:47 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Blow thru but bonnet design is VERY critical.
Mike @MM
Re: Blow thru carb or carb pressure box??? [Re: Blucuda413] #588483
01/21/10 01:43 PM
01/21/10 01:43 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
just wondering how much HP you are talking about?
i believe the box held it's own to about 12lbs of boost.i tried to find some print on the subject with no luck.
Re: Blow thru carb or carb pressure box??? [Re: blownzoom440] #588484
01/21/10 02:11 PM
01/21/10 02:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Extreme Air bonnet. Not sure they sell this type anymore. I forget his name (the owner) he says this type (plastic 2 piece) is good for up to 8psi.
My old 67 S/C'd 440
Re: Blow thru carb or carb pressure box??? [Re: Mr.Yuck] #588485
01/21/10 02:53 PM
01/21/10 02:53 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I use a bonnet by Extreme Velocity. Gordon is the owners name...good guy!!
