does msd still make the 6al with the 5 pin connetor? #587222
01/19/10 12:32 AM
01/19/10 12:32 AM
sandwich IL
sublimehemi Offline OP
sandwich IL
ive seen the msd 6al come with the 5 pin factory mopar plug in direct for mopar electronic harness,does anyone know if they still make? do you also need to run the 4 prong ballast resistor with this 6al?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587223
01/19/10 12:33 AM
01/19/10 12:33 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
no msd-6al with mopar plug..
the old msd-6c has the mopar plug...
still got one.
Tony
70 AARCuda Vitamin C
Re: does msd still make the 6al with the 5 pin connetor? [Re: 70AARcuda] #587224
01/19/10 12:40 AM
01/19/10 12:40 AM
sandwich IL
sandwich IL
their is a msd 6al with 5 pin that just sold on ebay,item #110477889585 so they did make it,there is also one currently for sale like the one you mentioned.
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587225
01/19/10 12:59 AM
01/19/10 12:59 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
ok,,,,learn something new...lol
the ebay auction shows a msd 6420....according to msd website it does not come with a 5 pin connector..
if you read the ebay ad that you reference it says list 6420 but with 5 pin...
so...?????
Tony
Re: does msd still make the 6al with the 5 pin connetor? [Re: 70AARcuda] #587226
01/19/10 09:50 AM
01/19/10 09:50 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
cool stuff,there where 5c and 6c and the 6c is multiple discarge variant,and if i remember it right instructions for both types says to use the 4 prong ballast.none off mine has rpm limiter.
Re: does msd still make the 6al with the 5 pin connetor? [Re: cuda-sweden] #587227
01/19/10 10:11 AM
01/19/10 10:11 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
WOOOW... INTERESTING... NOW I WANT ONE!!!
Re: does msd still make the 6al with the 5 pin connetor? [Re: NachoRT74] #587228
01/19/10 10:58 AM
01/19/10 10:58 AM
If they come in a 4 pin, me too
Re: does msd still make the 6al with the 5 pin connetor? [Re: RapidRobert] #587229
01/19/10 11:57 AM
01/19/10 11:57 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
no only 5 pins,at least those i have are 5 pins. BUT,hey hey hey,the one to have is a similar box made by msd for the ramchargers back then.i missed one of those on ebag a couple of months back these boxes are cool,there is a bit of reading in the d-c bible about them.
Re: does msd still make the 6al with the 5 pin connetor? [Re: cuda-sweden] #587230
01/19/10 01:12 PM
01/19/10 01:12 PM
NY
aarmaniac Offline
aarmaniac  Offline
NY
They made a 7C also. have one I tried. Sent it to MSD to repair. Never did try it.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
Re: does msd still make the 6al with the 5 pin connetor? [Re: aarmaniac] #587231
01/19/10 07:14 PM
01/19/10 07:14 PM
sandwich IL
sandwich IL
alright,i called msd and showed them the auction and they said he only thinks they made a 6c,and maybe someone modified that box with that connector ,i did not believe him,caue if you read the auction and look at the pictures it looks factory msd,he even ask his supervisor,i just emailed the guy whose box this was to see if this is stock or modified???so what do you guys think????somebody please post a link on the completed auction on ebay so we can get to the bottom of this?????i want one so baddddd even if i have to modify.........
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587232
01/19/10 08:06 PM
01/19/10 08:06 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Wow i am awake now, I bought this about 8 years ago with some other parts, NOS still in the box. Have yet to see another till now they are real but 30 years old. the shipping date on my box is oct 13 1980 (3 years before i was born)
Re: does msd still make the 6al with the 5 pin connetor? [Re: prochargedhemi] #587233
01/19/10 08:14 PM
01/19/10 08:14 PM
Is that a (5th) pin I see in the dim recesses . I sure woulda thought MSD would have built them for the hi perf 2 terminal ballast systems (4 pin).
Re: does msd still make the 6al with the 5 pin connetor? [Re: prochargedhemi] #587234
01/19/10 08:14 PM
01/19/10 08:14 PM
sandwich IL
sandwich IL
is that box multiple discharge or capacitive?is the 5c 6c and 7c multiple discharge?please explain does that one have a limiter?is it for sale?
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587235
01/19/10 08:27 PM
01/19/10 08:27 PM
iirc the pentastar plug in must be wired differently as it cannot be plugged in directly from an stock type ECU module over to these MSD's.
Re: does msd still make the 6al with the 5 pin connetor? [Re: RapidRobert] #587236
01/19/10 08:35 PM
01/19/10 08:35 PM
sandwich IL
sandwich IL
i have the new yearone 70 charger repro harness that has electronic conversion built in with the 5 pin connector set up for 4 pin ballast.i guess any of these this will work right?but the 6al has capacity discharge setup,do you just connect your ballast wires together cause its not multiple discharge like the 6c????
Re: does msd still make the 6al with the 5 pin connetor? [Re: RapidRobert] #587237
01/19/10 08:35 PM
01/19/10 08:35 PM
Temperance, MI
P
P
Temperance, MI
I have no idea if its multiple or capacity, it has no built in limiter but i always thought that these were for that?
would rather not sell, make good conversation pieces
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587238
01/19/10 08:45 PM
01/19/10 08:45 PM
this thread made me recollect a statement from ~20 yrs ago & iirc you cannot take the plug off an ECU & stick it on the MSD directly as the wiring is different & not (directly) compatible (without some wiring changes)& only the plug in (the pentastar shape) is visually identical.
Re: does msd still make the 6al with the 5 pin connetor? [Re: RapidRobert] #587239
01/19/10 09:04 PM
01/19/10 09:04 PM
sandwich IL
sandwich IL
i called the people who make my harness and he said it is wired to go either into 4 pin ecu or 5 pin ecu my harness has 5 shiny pin holes when you look into the pentstar.so this is not the 4 pin harness that does comes with the mopar performance electronic kit.......are you saying my harness will not even plug right to the msd 6al box on ebay and work????in need more info?????
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587240
01/19/10 09:19 PM
01/19/10 09:19 PM
From what I REMEMBER?? it will plug in identical but the MSD system is wired differently & will not work w a Mopar system AS IS whether your curent system is a 4pin ECU w 2 terminal ballast or a 5 pin ECU w a 4 terminal ballast. It lets you use the same (pentastar)plug in but you have to rewire the setup and you cannot switch back and forth at will which again if I am remembering this correctly means that you cannot stop on the side of the road & switch them then immediately compare the peformance difference which is the feature that I want. MSD does have a Nascar type coil selector and with some DTDT switches you could switch everything over. It'd probably take a fair amt of rewiring but it'd end up being a very nice immediate comparison (especially switching as your going down the road ).
Re: does msd still make the 6al with the 5 pin connetor? [Re: sublimehemi] #587241
01/19/10 09:30 PM
01/19/10 09:30 PM
sandwich IL
sandwich IL
alright guys,this is what i was wanting to do,i ordered this harness from yearone,its for my 70 charger converted to electronic ignition with 5 pin pentstar ecu plug.now when you get a factory harness converted from year one its like the 71 and up five pin set up with 4 pin ballast.its not the mopar performance 4 pin ecu set up from mopar performance.i called the harness tech line and he said you can run either 4 pin performance ecu box or five pin stock ecu as long as you run the 4 pin ballast anyway,i heard you can run it 2 ballast as well?i am wanting to get away from multiple discharge like orange chrome box cause i also want to get away with resistors as well so when i saw the msd 6al cd with 5 pin connector on the ebay auction,i was thinking of mounting that box under my batter tray and just plug in my connector cause it reaches over to it.....i think that a really stealthy set up.i am wanting to get the new firecore dizzy with mopar plug.so if i find a msd 6al with the 5 pin connector,like the one on ebay mentioned,and connect my ballast wires together??what else do i need to switch in the harness???
