1964 Body Stampings #587030
01/18/10 09:22 PM
01/18/10 09:22 PM
Tucson, AZ
73ChargerSE Offline OP
Tucson, AZ
Where are the body stamp locations on a '64? I found the one on the core support. Are there any others? Looked on the trunk rail, couldn't find anything. Would it be under the seal? Also, they are supposed to match the SO number on the fender tag, correct?
Thanks!
Re: 1964 Body Stampings [Re: 73ChargerSE] #587031
01/18/10 10:56 PM
01/18/10 10:56 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The other is on the rear package tray looking from the top down. You have to remove the upper rear seat and the liner to see it.
I think in 64 it's a 6 digit sequence and they should match the last 6 digits of the SO.
Re: 1964 Body Stampings [Re: 64Post] #587032
01/18/10 10:58 PM
01/18/10 10:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct, the SO number, not the VIN#. The SO number will be on the fender tag and some of the other paperwork (broadcast sheet, etc.).
