Re: F.A.S.T. Hemi dyno results/video
[Re: sogtx]
#584394
01/17/10 10:55 PM
01/17/10 10:55 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Hey Eddie, were gonna need all the smoke you and Mike can make this year. I have NO doubt you`ll be runnning at the top of the heap. The Mopars will be ready for battle..
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: DaveDudek]
#584395
01/17/10 11:14 PM
01/17/10 11:14 PM
Posts: 731 NY
XXHEMI
NY
Andy
It will be ready for the spring. Just waiting on two Modern items!
Looks like we will be at the Valley not Maple Grove though
[Re: Steve1118]
#584396
01/18/10 12:23 PM
01/18/10 12:23 PM
BradH
That's with the MP 6qut oil pan, correct? Any scarpers or any such animal? Has there been any sign of bearing issues when the motor is disassembled?
X2... since I run the MP 6-qt pan, too.
[Re: BradH]
#584398
01/18/10 01:30 PM
01/18/10 01:30 PM
DaveDudek
N of Detroit
I`m running a 6qt pan, crank scraper and a screen.
[Re: BradH]
#584400
01/18/10 01:38 PM
01/18/10 01:38 PM
DaveDudek
N of Detroit
NO, just a stock repo pan..
[Re: DaveDudek]
#584402
01/25/10 10:54 PM
01/25/10 10:54 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
sounds great Dave!! and great numbers too!! 770hp is huge!!
its interesting to see the differences in the way different shops test things. when i dyno a FAST type motor, i like to run it as close as possible to the way it will be run in the car. belt driven W/P, air filters in place, and the water temp in the 160-170 range.
[Re: DaveDudek]
#584407
01/26/10 06:33 PM
01/26/10 06:33 PM
Posts: 4,179 California
mickm
California
For the last 3 years all i have ran is a stock oil pump (no hi-volume or pressure) and the stock pick-up. I didn`t notice it in the car but the oil pressure drops 5 lbs from 6000 to 7500 RPM.
i first read that as "but the oil pressure drops TO 5 lbs from 6000 to 7500 RPM
glad i misread it!
[Re: fast68plymouth]
#584408
01/26/10 10:15 PM
01/26/10 10:15 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
dwyane noone runs 160-170 degree water in a drag race motor that i know... dave will run this in his car as close to 100 or colder if he can,, probably 120-140 if he is bracket type racing..
he left the air filter out for his own reasons and water pump... i dont know why but maybe he wanted to see how much power it makes without that stuff,,, he still need an aircleaner,, but there may be ways around that water pump,,, for people who look for every last hp
it was really just a baseline so dave could see where he was at,, so when it goes back together he knows he needs 800,, the same way,, no air cleaner,, etc...
[Re: sunroofgtx]
#584410
01/27/10 08:34 AM
01/27/10 08:34 AM
DaveDudek
N of Detroit
Rick, i`m looking fwd to those wires. As far as the dyno testing, Jeff`s right with the water temp. When i`m at the track i like to keep the water temp in the 100/120 area if possible. FAST is a heads-up class and i need to go fast. AS far as dyno`ing with the water pump, alt, air cleaner, etc,etc... I dyno lots of engines, i have a plastic container with the stuff i bring when dyno`ing a motor. Bottom line it`s just easier for me, that `s the way i do it. I`m just using the engine dyno as a basic tool, i`ll do the fine tuning on the rear wheel dyno or at the track while i`m using the complete exhaust system, fuel system, and all the stuff we actually have to run with, in the car were using.
