What to do with a 73 318 challenger???? 3-g HEMI #583906
01/16/10 01:37 AM
01/16/10 01:37 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
This project is from a few years ago but I have the pictures and will post in sequence of the build. It was a project that was caught in the middle of a divorce battle, and was never finished till we gained custody and made it our own. The first few pictures are of the car when It first rolled in the door, the body and paint was already done but that was it just a shell.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583907
01/16/10 01:47 AM
01/16/10 01:47 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Before anyone asks the Keystone Classics are already gone. Please anyone who takes over a project try to take a good inventory of what is there because the little things really add up fast when putting a complete car together.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583908
01/16/10 01:56 AM
01/16/10 01:56 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
The previous owner had a "professional body shop" do all the body work new quarters, trunk pan, drivers side floorboard, one inner wheel well and the new viper yellow paint. But what he didnt tell her was he was just gonna lay the new floor pan in over the old rusty one, put a few tack welds in and smooth some bondo around to look good but from underneath you can still see all the pin holes from the old pan so I cut it out and butt welded the new pan in the correct way. The grey primer is where the old pan was laid in there.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583909
01/16/10 02:00 AM
01/16/10 02:00 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Few more pics of the floorpan.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583910
01/16/10 02:05 AM
01/16/10 02:05 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Fixed, went over it with zero rust and primed and painted.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583911
01/16/10 02:10 AM
01/16/10 02:10 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
With everything out of the car what better place to start than with the wiring.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583912
01/16/10 02:20 AM
01/16/10 02:20 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Just so ya know the date stamp on the pictures isnt always correct. But its time for a little interior work....
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583913
01/16/10 02:24 AM
01/16/10 02:24 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Looking back why I didnt take out the steering column in the first place is beyond me because it was always in the way.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583914
01/16/10 02:40 AM
01/16/10 02:40 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Having never put complete windows and regulators in a car it was very intimidating but with some help from some good people on moparts they went in and worked.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583915
01/16/10 02:46 AM
01/16/10 02:46 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Not doing the instrument cluster/dash wiring with the dash out of the car may be something you ask yourself about later also. On my son's '73 SSP we did all the wiring with the dash out of the car and it was easy as pie. Connect everything on the back side of the dash and THEN put it in the car. Once you set the dash in the car all you have to worry about is running the harness down the driver side kick area and attaching the bulkhead connector to the firewall. No laying on your back struggling under the dash BS.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: Hotwheelsjr] #583916
01/16/10 11:44 AM
01/16/10 11:44 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
yep figured that one out also would have been so much easier......not to mention the heater box first also
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583917
01/16/10 11:57 AM
01/16/10 11:57 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
The good thing is the seats were in about perfect shape so with a little cleanup on the tracks and some new grease they were ready to bolt in.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583918
01/16/10 12:18 PM
01/16/10 12:18 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Engine with weldtec oil pan motor plates and xv intake.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583919
01/16/10 02:09 PM
01/16/10 02:09 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Checking how the motor fit into the car
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583920
01/16/10 02:12 PM
01/16/10 02:12 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
only issue was with the alternator to frame rail clearance....just a little tight, nothing a cutoff wheel couldnt take care of.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583921
01/16/10 02:21 PM
01/16/10 02:21 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
next
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583922
01/17/10 06:15 PM
01/17/10 06:15 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Got the glass in.
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583923
01/17/10 06:20 PM
01/17/10 06:20 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Demon carb MSD HEMI 6 controller. And this baby is ready to fire.......
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583924
01/17/10 06:25 PM
01/17/10 06:25 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
more
Re: What to do with a 73 318 challenger???? 3-g HEMI [Re: drgordi] #583925
01/17/10 06:33 PM
01/17/10 06:33 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
There were a few pieces that were not painted and after getting them into shape and painted I think I know why the "pro body guy" quit when he did. He never test fit the rear valance when he put the new quarters on the car. The next few pics will show why its better to always test fit all parts as you progress with a car.
