Re: air grabber hoods and intakes
[Re: GTXKen]
#581351
01/13/10 08:00 PM
01/13/10 08:00 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
If you want to retain the air grabber air cleaner the answer is yes. If you just want to run the hood without the fiberglass under the hood you have more room. I run a RPM on my 70 with a 2.5" drop base and my lid just hits the bulge hood.
Ken, With the RPM, how is it with the air grabber 440 base? I have a '71, but the clearance should be the same. Jim
[Re: 1fastrunner]
#581353
01/14/10 01:57 PM
01/14/10 01:57 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
I could probably get the base on but never the top half which seals it to the hood.
[Re: GTXKen]
#581355
01/14/10 02:28 PM
01/14/10 02:28 PM
Posts: 1,647 IL
71383beep
IL
Wait a minute...is this with a RB stroker or a BB stroker?
The 383/400 block is lower and i thought that the AG setup could still function with an RPM manifold and the 440 air cleaner.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: bigblockbryan]
#581356
01/14/10 02:42 PM
01/14/10 02:42 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I built a 505 stroker based on a 440 block and used a performer RPM intake. I bought a fibreglass air cleaner base and cut a large hole in the middle (around 13"), then fibreglassed a 1 3/4" drop-base to it. Hood clears the air cleaner and the base seals nicely.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
