Budget build 360 with 425 HP How????
#58065
05/09/08 06:32 PM
05/09/08 06:32 PM
Posts: 406 Houma, Louisiana
twister360
Houma, Louisiana
I would like to build a 360 with about 425 HP for a 75 Dart Sport. How would you do it on a budget and what parts would you use and how much do you think it would be to build? It would be basically a street car with a trip to the track occassionally.
My car 74 Duster mild 360/904/3.91 13.44/101.54
Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408
2004 Dodge Ram 1500 Laramie 5.7
2010 Dodge Challenger R/T Classic B-5 6 speed
2010 Jeep SRT8 for the little wife
Re: Budget build 360 with 425 HP How????
[Re: DaytonaTurbo]
#58068
05/09/08 08:35 PM
05/09/08 08:35 PM
NOS
#58069
05/09/08 08:39 PM
05/09/08 08:39 PM
twister360
Houma, Louisiana
BTW it's going to be a Magnum 360. My dad's car is over 425hp (360 Magnum) and it's not stroked.
[Re: twister360]
#58070
05/09/08 09:58 PM
05/09/08 09:58 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Have a shop that does performance engine builds do it. There is no budget way to make 1.5hp/cu inch. But you can do it less expensive. If the engine is a running core, you can re-use the spider and lifters. Have the heads done for performance. I'd have to snoop into cam profiles, and I'd run the MP single plane intake, and probably get some good forged dished pistons and run a cam tht wouldnt keep enough vacuum for power brakes but would bleed off pressure. The only issue is, the power wont be there until mid range rpm. Not a ton of torque below 3000 rpm. 425hp will cost you at least $5K done right by someone for you.
[Re: Evil Spirit]
#58074
05/10/08 11:05 AM
05/10/08 11:05 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
The crate Mag 380hp 360 makes good power and all they change are the cam, springs, and intake. A production 360 with the same or similar cam/springs/intake, milled and slightly ported heads and you are probably at the 425hp mark that you are trying to do.
This is exactly what you need to do. For that amount of hp get the KB pistons #107 or the forged counterpart but hyper would be fine and budget oriented. Do some basic clean up of the ports, open the bowls, and pushrod pinch a little, get the valves back cut, and smooth the ports out a little. Un ported those heads can easyly make a 400 hp street 318 so get a little mo flow and cubes and 425 is not hard at all and don't really need to turn much over 6000, mabey 6500 tops.
[Re: DaytonaTurbo]
#58075
05/10/08 01:59 PM
05/10/08 01:59 PM
Posts: 1,044 minnesota
president61
minnesota
Not gonna happen unless you go with a stroker setup, which IMO does not fit my definition of a 'budget build'. You can however get 375hp out of a streetable, stock stroke 360. I'm not saying the 425 can't be done, however you'd have to spin it to 7k and run a monster huge cam in it which would not be streetable.
I totally disagree. High Performance Mopar mag. did a build up several years ago and got 430hp from a mild 360. Pump gas, ported smog heads, Thermo carb, and stock crank. If you want I can look up the exact specs.
[Re: Jerry]
#58078
05/10/08 07:33 PM
05/10/08 07:33 PM
twister360
Houma, Louisiana
Some great replies. Like I said I'm going to be getting a running 360 Magnum motor. My main thing will be figuring out what parts I'm going to go with and shop around for the best prices. I'll probably go with what my dads current setup is, but not go through the machine shop for parts. The Magnum motor that I'm looking to purchase is from a van and the price is $800. Which seems to be a little high, should I offer less?
[Re: 84Stepside]
#58081
05/10/08 08:52 PM
05/10/08 08:52 PM
president61
minnesota
i would be interested in the specs
I found the build up I was thinking of but its not the right one. I'll keep looking. Anyway this particular build up consisted of: 78 360 block and heads(home ported), 9:1 comp, Summit cam 441 lift, Performer RPM, 750 Holley, Hedman headers, and quality machine work. It moved a 1972 Challenger to Mid 12s. they didn't give any HP#s.
[Re: twister360]
#58082
05/10/08 09:19 PM
05/10/08 09:19 PM
HotRodDave
Kalispell Mt.
If you pretty much want to keep what you have then pull the heads off dissasemble the short block and have .070 taken off the deck to get the pistons at zero deck. Use a .039 felpro head gasket. Doing this will give a little more compression and quench, both of witch will help hp and tq. Put in a nice roller cam about like the crate motors and a airgap intake. You would only have to buy a gasket set and about $100 machine work and 400 hp is very easy, it would probably make about 415. A little port touch up and a back cut of the valves should give the 425hp.
$800 is a little high around here but not much. $800 will get a late production low miles 360 mag motor here.
[Re: president61]
#58083
05/11/08 01:42 AM
05/11/08 01:42 AM
DaytonaTurbo
Manitoba, Canada
Again, I doubt that build fits the OP's "budget build" requirement. The headwork needed to get there(or the $ for the aftermarket magnum r/t heads the crate engines run, or other aftermarket heads) plus machine work, plus all required parts, and you total up the $ spent at the end and that does not fit my definition of a budget build, maybe yours, but not mine.
[Re: DaytonaTurbo]
#58084
05/11/08 03:50 AM
05/11/08 03:50 AM
twister360
Houma, Louisiana
After the complete motor is bought. My budget would be in the 2000 dollar range to build it up.
