rough guesses 1/8th and 1/4 mile times #580623
01/12/10 08:09 PM
01/12/10 08:09 PM
kentucky
roadrunner7020 Offline OP
kentucky
My street car is a 1970 B body full interior 440 with around 10.5-1 compression eddy aluminum closed chamber heads (stock no port work), adjustable rockers, lunati voodoo 60305 cam (if i remember right), Weiand high rise alumium intake, Hooker competition headers out to 2 1/2 inch exhaust and a 750dp holley. Transmission is a 727 auto with 3000-3500 stall cheetah reverse manual valve body all been rebuilt recently with a 4.2 lever. Rear gear in a 8 3/4 suregrip is a 3.55 running a 28 inch tire will be running slicks at the track.
This is my street car however i will run it at the track on occasions wondering what to expect on both the 1/8th and the quarter mile.
Thanks in advance
Re: rough guesses 1/8th and 1/4 mile times [Re: roadrunner7020] #580624
01/12/10 08:12 PM
01/12/10 08:12 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I would expect 12:40s- 12:70s at about 109mph
Re: rough guesses 1/8th and 1/4 mile times [Re: mercman1] #580625
01/13/10 05:00 AM
01/13/10 05:00 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Mid-13s.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: rough guesses 1/8th and 1/4 mile times [Re: roadrunner7020] #580626
01/13/10 08:56 AM
01/13/10 08:56 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
8.61 in the 1/8 mi.
Re: rough guesses 1/8th and 1/4 mile times [Re: buildanother] #580627
01/13/10 06:11 PM
01/13/10 06:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
did you degree the cam??
Re: rough guesses 1/8th and 1/4 mile times [Re: roadrunner7020] #580628
01/13/10 06:36 PM
01/13/10 06:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would say you should be running deep 12's in the 1/4 if everything is tuned well. If you were to change to a more aggressive gear like a 4.10, header cutouts and an 850cfm carb you should be in the 11's.
Re: rough guesses 1/8th and 1/4 mile times [Re: DaytonaTurbo] #580629
01/14/10 02:59 AM
01/14/10 02:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ron
Re: rough guesses 1/8th and 1/4 mile times [Re: 383man] #580630
01/14/10 12:40 PM
01/14/10 12:40 PM
kentucky
kentucky
Thanks everyone i will most likely go to header cut outs before track season and had thought about steeping up to 3.91 gears or so but i really like the highway rpms right now vs what they would be as this is primarily a street driver
Re: rough guesses 1/8th and 1/4 mile times [Re: roadrunner7020] #580631
01/14/10 12:46 PM
01/14/10 12:46 PM
P
Paul_Fancsali Offline
P
Thr 28 inch tires and the 3.55s are going to hurt your times period. A 25-26 inch tire would give you the times and still allow the 3.55s. Myself I would go with the 4.10s or 4.30s
Re: rough guesses 1/8th and 1/4 mile times [Re: Paul_Fancsali] #580632
01/14/10 01:28 PM
01/14/10 01:28 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
12.30's-12.40's @ 110...
