Re: 500 stroker motor with 9.1 compression
[Re: Quicktree]
#578506
01/11/10 01:14 PM
01/11/10 01:14 PM
DaytonaTurbo
Manitoba, Canada
Have not fired it up yet, still waiting for parts to drop it in. What about a mixture of 93 octane and 110, maybe 2 gallons of 110 to 3 gallons of 93 in a 5 gallon jug?
you probably need it. you do know the more octane you use the slower the burn rate right? I would start with regular 93 and work your way down.
That's a lower CR but a lot of cubes with a mild cam. I would do the initial break-in with a mix of pump 93 and race gas, just to feel safe during the cam break-in and initial driving stages. After than I'd go with straight pump 93 and tune/step down from there.
[Re: 1AARCUDA]
#578507
01/11/10 01:47 PM
01/11/10 01:47 PM
Posts: 502 North Texas
1AARCUDA
North Texas
I had no clue 110 burns slower, I will go with straight 93 and test and tune from there. Makes sense that my car ran slower toward the end of my season I was running straight 110, It was a 440 with 9.5.1 compression, I thought i could run better with straight 110.
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
[Re: 1AARCUDA]
#578508
01/11/10 01:48 PM
01/11/10 01:48 PM
1AARCUDA
North Texas
What is Black bearing? Never heard that term before
1970 AAR CUDA
1986 Shelby GLHS
[Re: DaytonaTurbo]
#578509
01/11/10 05:22 PM
01/11/10 05:22 PM
Quicktree
I meant to say probably don't need it
[Re: Quicktree]
#578510
01/11/10 06:08 PM
01/11/10 06:08 PM
DaytonaTurbo
Manitoba, Canada
Yeah that's what I figured. That's why I say he's better off safe than sorry during the initial break-in process. Once the cam break-in's done and a little driving under his belt and some tuning done, pump gas should do him fine.
[Re: 1AARCUDA]
#578511
01/11/10 10:09 PM
01/11/10 10:09 PM
Posts: 600 Spartanburg SC
MoparDan
Spartanburg SC
i was wondering the same thing..
