Re: Degree a camshaft
[Re: Moneypit6]
#578217
01/10/10 10:56 AM
01/10/10 10:56 AM
RapidRobert
you'd need to replace 2 hyd lifters w solids to get an accurate read on your dial indicator on the end of the (2) pushrods
[Re: RapidRobert]
#578218
01/10/10 03:58 PM
01/10/10 03:58 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Why 2 solid lifters one on the intake lobe with a solid cup type push rod and if you want to degree the exhaust move it over. Nice to have the intake off though
[Re: Dodgem]
#578222
01/10/10 08:43 PM
01/10/10 08:43 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i think that threaded rod will bend.i used a grade 8 bolt.at 1" length it stopped my piston at 10BTDC with the tdc of the piston being .060 in the hole.
[Re: blownzoom440]
#578223
01/10/10 09:15 PM
01/10/10 09:15 PM
Dodgem
Ontario, Canada
I bin using that one for 18 years never bent it yet??? It gets sandwiched between the piston and head how is it going to bend?
[Re: Dodgem]
#578224
01/10/10 09:30 PM
01/10/10 09:30 PM
blownzoom440
ELYRIA,OH
not to make a major case out of it the plug hole is at a 45*[guessing the angle]to the piston.i have a head off the block .if the plug linesup with the chamber roof i will agree with you.no big deal if it workds for you.cool!
