Page 3 of 3 1 2 3
Re: Rebuilding an AVS and wondering about mods. [Re: 1MYTGTX] #578097
01/12/10 05:38 PM
01/12/10 05:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What does everyone do for the yellow cad plating on the rods? Eastwoods paint system or actually have them cad plated somewhere?
I use an outside plater, there are several colors involved in doing most carbs. Nothing else looks right IMO.
Re: Rebuilding an AVS and wondering about mods. [Re: 1MYTGTX] #578098
01/14/10 07:48 PM
01/14/10 07:48 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
Here are some more pics. This is the port where the A/C equipped cars have that thermostatic air bleed that was on this carb, but the port wasn't drilled.
Here's the bottom:
I started with this:
I removed the plugs with these tools, turning by hand, and this is what came out:
I wish someone told me that the threads go all the way to the front of the carb. I thought the idle screws were smaller than the normal ones, and people tapped the holes for the bigger adjusters. Well, I didn't damage the threads, so all is good. I'll use the adjusters from the Edelbrock if they fit instead of the small ones.
As for that off idle adjuster--if I have problems, I'll just plug the hole.
Re: Rebuilding an AVS and wondering about mods. [Re: 375inStroke] #578099
01/14/10 10:24 PM
01/14/10 10:24 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I just re-used the stock mixture screws. They work just fine, you just need a long skinny straight blade screw driver to reach in there, not a big deal. I picked the lead plugs out of mine with some dental type metal picks.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Rebuilding an AVS and wondering about mods. [Re: GO_Fish] #578100
01/15/10 03:33 AM
01/15/10 03:33 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
If you use the bigger screws with the springs, they are less likely to self adjust.
Page 3 of 3 1 2 3
