Dakota tailgate Not Closing #577273
01/09/10 11:42 AM
01/09/10 11:42 AM
NY
old340dog Offline OP
NY
Does anyone have a problem with there dodge Dakota tail gate not closing? I have a 2004 and when I shut the the tailgate it does not want to close and stay latched. Flops open when I hit a bump. My sons (2001) dakota had same problem when he had his. There is a tab on right outtside of tail gate the you have to push down to get the latch to stay closed. This must be a problem on others as well. Was wondering if others have had the same problem and what they did to fix it.
old340dog
Re: Dakota tailgate Not Closing [Re: old340dog] #577274
01/09/10 12:03 PM
01/09/10 12:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sounds like the strikers (located on the inner bed sides) may need some adjusting. You can adjust them about 1/4" concentrically.
Re: Dakota tailgate Not Closing [Re: old340dog] #577275
01/09/10 12:08 PM
01/09/10 12:08 PM
Detroit, MI
RawnDart Offline
RawnDart  Offline
Detroit, MI
I had that problem for a while on my '97. I adjusted the strikers a little bit, and it got better. It got fixed for good when the truck got rear-ended, and the tailgate had to be replaced.
Re: Dakota tailgate Not Closing [Re: old340dog] #577276
01/09/10 12:16 PM
01/09/10 12:16 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Lube the little tabs at the latches. I've had to do that once in 4 years. Drop the gate and you'll see the little square thingamajigs in there at each latch, that move when you operate handle. Work at it, spray it, it should straighten right out.
Re: Dakota tailgate Not Closing [Re: buildanother] #577277
01/09/10 12:26 PM
01/09/10 12:26 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
The tailgate handle you pull to open it is probably rusted and sticking causing the latches not to close. Remove the handle and check the pivot,it is shaped like a X inside of tailgate.
Re: Dakota tailgate Not Closing [Re: mod381] #577278
01/09/10 12:44 PM
01/09/10 12:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Spray some PB blaster into the latches and work the handle. Lubrication does wonders.
Re: Dakota tailgate Not Closing [Re: MoparforLife] #577279
01/09/10 02:26 PM
01/09/10 02:26 PM
NY
NY
I've lubed the pivits point several times helps for a while, but haven't adjusted the strikers.Was wondering if there is a way to get latch assembly out for a good cleaning or lubing without a major overhaul?
old340dog
Re: Dakota tailgate Not Closing [Re: mod381] #577280
01/09/10 03:31 PM
01/09/10 03:31 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Sam deal on mine..ended up taking latch handle out and soaking it for a few days..
Re: Dakota tailgate Not Closing [Re: old340dog] #577281
01/28/14 12:24 AM
01/28/14 12:24 AM
ny
1960dodge Offline
1960dodge  Offline
ny
did you ever get your 2004 dakota tailgate to work right?.....mine has the same problems and there is NO access panel...help!
