the stacked plat cooler are a little more efficant at cooling
a finned tube one is fine if its large enuff for the appliction
I use 3/4 inch heater hose cut in 2" lengths to go between the rad fins and the finned cooler to keep a gap inbetween the cooler and rad
thats with the plastic zip ties they come with that you poke thru the rad core
best way would be mount it to the core support with flat metal to be a little more ridged
the gap will keep it from damaging the fines of rad core and not collect dirt and clogg the air flow thru it
![](/ubbthreads/images/graemlins/Twocents.gif)
