Driveshaft question #576701
01/08/10 05:49 PM
01/08/10 05:49 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
How much should the slip yoke be into the transmission? I have 1=5/8" remaining after it is in, is this far enough? I can't find out what the length of the shaft should be as I have a 72 Cuda 340/904 with 8-3/4 rear and all literature does not address this combo.
Re: Driveshaft question [Re: JonC] #576702
01/08/10 05:54 PM
01/08/10 05:54 PM
scratchnfotraction Offline
shove the yoke all the way in till it bottoms out
measure the center of yoke to center of yoke on rear axle
subtract 1 inch..thats the length drive shaft you need and the slip yoke will be in the correct operating zone
Re: Driveshaft question [Re: scratchnfotraction] #576703
01/08/10 06:34 PM
01/08/10 06:34 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Using this method The driveshaft I currently have is 1/2" short is this too much? Can it cause vibration?
Re: Driveshaft question [Re: JonC] #576704
01/08/10 08:18 PM
01/08/10 08:18 PM
IMO..no its not to short
vibs can be a few things...
has it been cut?
does it have weld on weights missing? (look for spots that a tac weld has been there)
does it have any dings/dents/bent in the shaft?
are the yokes in good shape?
(caps need to be tight in the yoke and not spinning)
you can have it balenced fairly cheap and is good $ spent in the long run
how is the tailshaft bushing in the tranz itself?
Re: Driveshaft question [Re: scratchnfotraction] #576705
01/08/10 08:38 PM
01/08/10 08:38 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I've posted the vibration thing a couple of times, driveshaft has been recently balanced. It was suggested by some to check the drivshaft length, which I am doing with this post. Others said to replace the tailshaft bushing and bearing which is my next project. I just want to make sure the 1/2" doesn't make a difference before I proceed with the bushing etc. including replacing the slip yoke.
Re: Driveshaft question [Re: JonC] #576706
01/09/10 10:47 AM
01/09/10 10:47 AM
I have used a seal with dust boot and cut the drive shaft
shoved all the way in and subtraced 1.5 inches with no problem
1/2" should be fine IMO
I have had them up to 2" from bottoming the yoke,dont remeber haveing any trouble with it either
but the 1" is rule of thumb and 1.5 is not that much more
Re: Driveshaft question [Re: scratchnfotraction] #576707
01/09/10 11:25 AM
01/09/10 11:25 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I measured mine with the dust boot on, should I remove it and measure it?
Re: Driveshaft question [Re: JonC] #576708
01/09/10 11:56 AM
01/09/10 11:56 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Jon, I just had a new shaft made yesterday. If you go to Dennysdriveshafts, they have a form you can print off that tells you clearly how to properly measure for driveshaft length. I used it just to double check myself, and I filled it out and took it to my local D/S maker and they appreciated having a sheet that clearly spelled out what they needed to do! Just my .02. Lee.
Re: Driveshaft question [Re: Lee446] #576709
01/09/10 12:25 PM
01/09/10 12:25 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Why not just put up the link?
Dennys Driveshafts - How to Measure Correctly
