Anyone run AutoZone / Duralast Sealed U-Joints #576579
01/08/10 12:57 PM
01/08/10 12:57 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I'm likely going to need new u-joints. The one's on my truck are very loose and with the new mill going in and harder shifting transmission I'm going to need to replace them.
I noticed that Durlast makes a sealed, maintenance free u-joint. Some things that Durlast makes have actually been decent quality in my book. Other things have been garbage. I was wondering what you all thought about these u-joints.
In addition, how do I measure the size of the u-joint. I measured the cap diameter (1.125) and the cap to cap length (3.626 IIRC) but that doesn't line up with any of the measurement I see here so I'm taking the wrong measurement but don't know what.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Chilort] #576580
01/08/10 01:02 PM
01/08/10 01:02 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I don't know specifically about those but I would find out if they are cast or forged. A picture should be able to tell.
You WANT forged!
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Pacnorthcuda] #576581
01/08/10 01:12 PM
01/08/10 01:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use nothing but Brute Force.Advanced has them.Solid joint and high quality.I pretty much used them all the time at the shop also.Rocky
Chrysler Firepower
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: therocks] #576582
01/08/10 01:35 PM
01/08/10 01:35 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
This should link to the AutoZone part
http://contentinfo.autozone.com/znetcs/product-info/en/US/nsm/1-6301DG/image/8/
Looks like a number of places carry the Brute Force u-joint and it is packaged as several brands. They are made by Neapco.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Chilort] #576583
01/08/10 01:42 PM
01/08/10 01:42 PM
NE
moparpoolman Offline
NE
I like Spicer joints! I've had them in my car with slicks and a 4spd for a few years now and no problems. I wouldn't be as preferable if it was just a street car.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Chilort] #576584
01/08/10 02:06 PM
01/08/10 02:06 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
I haven't seen them yet, (I usually stay out of Auto Zone) but if you want me to test them, send me a set of 1-6301's for a 318 '73 Satellite and wait a month or so... I'm on my 10th one since installing the big rear tires.
The Blue Goose
My instagram: Bossride
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: BossRide] #576585
01/08/10 02:07 PM
01/08/10 02:07 PM
They way I abuse junk I just pony up and buy Spicer.
Re: Anyone run AutoZone / Duralast Sealed U-Joints #576586
01/08/10 02:19 PM
01/08/10 02:19 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
It didn't help.. I have the smallest U-joint they make and my rear tires are HEAVY, almost as heavy as my right foot. They don't stand a chance.
I'm dreaming of getting a different/stronger rearend with a better gear and a new drive shaft one day.
The Blue Goose
Re: Anyone run AutoZone / Duralast Sealed U-Joints #576587
01/08/10 02:25 PM
01/08/10 02:25 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
Alright now i need somebody to chime in here and say something good about the duralast joints doggonit, i just put a set in the CUDA.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Lew] #576588
01/08/10 02:48 PM
01/08/10 02:48 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Go beat the snot out of them and tell me if they are any good!
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Chilort] #576589
01/08/10 03:09 PM
01/08/10 03:09 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
to much snow goin on here today, will probably be awhile.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Lew] #576590
01/08/10 03:19 PM
01/08/10 03:19 PM
Based on what I see here (Forged center section) they appear to be a good joint. Not sure why the "sealed" is considered advantageous though. I would rather have the grease fitting.
BTW--its good practice to install the fitting (or in the case the 'bump' where the fitting would normally be) in COMPRESSION. Meaning align it so that under power the driving yoke is squeezing it between the driven yoke, rather than trying to rip it apart. Use your fingers like a set of yokes and you'll get what i mean. The weakest part of the center section is where the fitting is located.
No its not LIKELY to ever fail, but this removes it from the equation.
http://www.duralastparts.com/gold.php?page=ujoints
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Pacnorthcuda] #576591
01/08/10 04:02 PM
01/08/10 04:02 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The reason I run a sealed joint is becuase they are solid where the greasable ones are hollow through the center to allow grease to pass to the caps.
The solid joints are stronger.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Pacnorthcuda] #576592
01/08/10 04:05 PM
01/08/10 04:05 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
Well i got the Gold with lifetime warranty, so if it blows, tears off my tailhouseing, shatters the rear yoke and throws the drive shaft threw the floor, THEY WILL give me a new GOLD JOINT, RIGHT?
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: WILD BILL] #576593
01/08/10 04:09 PM
01/08/10 04:09 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Now we are talking... I might look into these for this reason. I think the hollow section distorts in mine and allows for movement which then beats the roller bearings around.
Thanks!
Ill keep you guys posted on mine. They go out pretty quick if I drive hard.
The Blue Goose
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: BossRide] #576594
01/08/10 04:18 PM
01/08/10 04:18 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I just like the idea of one less thing to have to grease. The notion that they are stronger is nice. Think I'll pick up a pair.
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Chilort] #576595
01/08/10 06:59 PM
01/08/10 06:59 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I couldn't believe my D350CTD has sealed joints. No telling how long they have been in there.
I like a U joint with a Zerk fitting in the center of one of the bearing caps. That looks really strong!
That what my van has. And they aren't factory!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: Chilort] #576596
01/08/10 08:06 PM
01/08/10 08:06 PM
iirc on the inside of the yoke from one ear to the other is 2&1/8" on the small one (7260) and 2&5/8" on the large one (7290)
Re: Anyone run AutoZone / Duralast Sealed U-Joints [Re: RapidRobert] #576597
01/08/10 10:22 PM
01/08/10 10:22 PM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
Have run solid Duralast joints in both GTX convertible and Duster with no issues. Quality seems good.
