275/60/15 on 7" rim ? #576535
01/08/10 10:46 AM
01/08/10 10:46 AM
Texas
Texican Offline OP
Texican  Offline OP
Texas
It may not be the best fit, but is anyone running 275/60/15's on a 7" steel wheel ?
Will it work ?
I'm talking about the rear tires of course...
Mike
Re: 275/60/15 on 7" rim ? [Re: Texican] #576536
01/08/10 10:49 AM
01/08/10 10:49 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
About a million people run that combo.
Re: 275/60/15 on 7" rim ? [Re: sixpack4spd] #576537
01/08/10 11:06 AM
01/08/10 11:06 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
I run it on a 8,but I am sure plenty of people do it.Its just going to make the tire look different.The tire shop will explain that to you.
Re: 275/60/15 on 7" rim ? [Re: Texican] #576538
01/08/10 02:17 PM
01/08/10 02:17 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
No problem. Works better with an 8" rim, but it will work and look OK with a 7.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 275/60/15 on 7" rim ? [Re: Junky] #576539
01/08/10 03:01 PM
01/08/10 03:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run it on a 7" rim. It makes the tire bulge a bit and makes it look narrower than the same tire would on a 8-9" rim. Works fine, traction is fine, seems to put down a solid looking patch of rubber.
Re: 275/60/15 on 7" rim ? [Re: Junky] #576540
01/08/10 03:01 PM
01/08/10 03:01 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I have them on a 6.5" rim right now. I am going to go with an 8" sometime this summer.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 275/60/15 on 7" rim ? [Re: Texican] #576541
01/08/10 03:04 PM
01/08/10 03:04 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Can't be much worse than the factory putting 31x10.50's on 7" wides, and I actually saw some 33x12.50's on the same 7" wides.
Re: 275/60/15 on 7" rim ? [Re: Prodart440] #576542
01/08/10 03:04 PM
01/08/10 03:04 PM
Kirkland, Washington
Pacnorthcuda Offline
Wow...I would like to see a pic!
Re: 275/60/15 on 7" rim ? [Re: Texican] #576543
01/08/10 04:12 PM
01/08/10 04:12 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Will it work ?
Mike
Those are called hillbilly rim savers...
Re: 275/60/15 on 7" rim ? [Re: Lefty] #576544
01/08/10 05:34 PM
01/08/10 05:34 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
They will fit on 7",but 8" is best and is preferred.
With an 8" rim you get the full benefit and advantage of the 2756015 tire.
I mounted one of each and stood them side by side at my shop.
You can physically see the difference.
If you do not match the rim accordingly to the tire--you are wasting your money..IMHO.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 275/60/15 on 7" rim ? [Re: Pacnorthcuda] #576545
01/08/10 06:25 PM
01/08/10 06:25 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
