Rubber grommets for auto shift linkage... #57531
04/29/08 12:53 AM
04/29/08 12:53 AM
Vista, California
ChickMaggot Offline OP
Vista, California
This is for column shift linkage. Where can I get'em?
I see Mr. Ehrenberg carries the plastic bushings but not the rubber grommets.
Mine are pretty dried out. Help!
Thanks, fellas.
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Rubber grommets for auto shift linkage... [Re: ChickMaggot] #57532
05/04/08 11:38 AM
05/04/08 11:38 AM
Vista, California
Vista, California
Anyone?
Re: Rubber grommets for auto shift linkage... [Re: ChickMaggot] #57533
05/04/08 04:00 PM
05/04/08 04:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In many installations the rubber grommets are a common hardware store item.
Re: Rubber grommets for auto shift linkage... [Re: ChickMaggot] #57534
05/05/08 12:44 AM
05/05/08 12:44 AM
Vista, California
Vista, California
I'm sure that's true, but these look specific to the task. They've got a ridge inside that seats into a furrow in the linkage
I found out the part number is "3575 333"
Re: Rubber grommets for auto shift linkage... [Re: ChickMaggot] #57535
07/01/08 11:45 AM
07/01/08 11:45 AM
Vista, California
Vista, California
Re: Rubber grommets for auto shift linkage... [Re: ChickMaggot] #57536
07/01/08 03:35 PM
07/01/08 03:35 PM
Troy, TX
74Sport Offline
74Sport  Offline
Troy, TX
I had one in my hand yesterday. My local Dodge dealer's parts department has it in stock. I was looking for some for a floor shifter, but this is all he had.
Let me know if you want it and I'll get the dealer info. so you can contact them.
Jerry
There's a difference between ignorance and stupidity. Ignorance is not knowing any better. Stupidity is knowing, yet doing it anyway.
Re: Rubber grommets for auto shift linkage... [Re: 74Sport] #57537
07/01/08 05:41 PM
07/01/08 05:41 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Im needing the one for a 70 column lock out rod.
Would it be the same?
Re: Rubber grommets for auto shift linkage... [Re: 74Sport] #57538
07/01/08 09:08 PM
07/01/08 09:08 PM
Vista, California
Vista, California
Jerry
Please assume that I'm interested in any leads.
Re: Rubber grommets for auto shift linkage... [Re: ChickMaggot] #57539
07/03/08 09:18 AM
07/03/08 09:18 AM
Troy, TX
74Sport Offline
74Sport  Offline
Troy, TX
This is weird...
The same day you asked about those bushings, my son came home with this one I told you about. His old one is at the side for comparison.
Here is the dealer's contact info:
Mac Haik Dodge
3207 S. General Bruce Dr.
Temple, TX 76504
(254) 774-5000
I don't know how many more they have in stock, but I believe these bushings are fairly easy to find.
Let me know if you need any more help,
Jerry
