summit Discount Code 2RETYV #574431
01/05/10 10:55 PM
01/05/10 10:55 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Whats up with the summit discount code 2RETYV. Says its invalid when input but the coupon says valid until Aug 2010.
Re: summit Discount Code 2RETYV [Re: FIREGUY12] #574432
01/05/10 11:12 PM
01/05/10 11:12 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
Used it yesterday, even with the "proshop" discount it worked?
Re: summit Discount Code 2RETYV [Re: FIREGUY12] #574433
01/05/10 11:13 PM
01/05/10 11:13 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
most likely you entered it in the wrong box. I think the first box is labeled for gift certificates or something. Look for a second box labeled for discount codes.
Re: summit Discount Code 2RETYV [Re: FIREGUY12] #574434
01/05/10 11:14 PM
01/05/10 11:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used it last night. Saved $65. Make sure you put it in the discount column. It's on the lower right side of the page.
Doug
